11-30-2014, 09:00 AM   #1
bethp
Guest
Pentax K7 No Red light on distance shots
Recently on our Sigma 18-50 &70-300 lens on our 4 yr old K7 Pentax the shot will not take if it is a distance shot. I can trick it by moving the small wheel at the front of the lens all the way to the right, then the red auto focus light will show & a beep will sound & the shot will take. Is it a lens problem (strange that it is happening with both lenses) or a camera problem. I can't find any settings that may have inadvertantly changed though on the camera.
11-30-2014, 09:06 AM   #2
aleonx3's Avatar
Are those auto focus lenses? Sounds like the k-7 does not recognise the auto-focus lenses; if they are, you have to turn the aperture ring setting on the lens to 'A', otherwise, the k-7 will treat it as manual focus lens.
11-30-2014, 10:42 AM   #3
c.a.m's Avatar
Several thoughts:
Are the two lenses - which I assume are autofocus types - actually moving to try to focus your shots when you 'half-press' the shutter button?
Do you have any other lenses that work ok?
Check the front of your camera to see if the Auto/manual focus switch has been inadvertantly moved to "MF" - it should be in the AF-S or AF-C positions for the autofocus function to work.
- Craig
12-02-2014, 09:26 PM   #4
QuoteOriginally posted by First Poster Quote
The red indicator in the viewfinder indicates the active focus point only. If it is not lit, it means that either the AF is turned off or none of the focus points are able to attempt focus. In the first case, MF should display in the viewfinder. In the second case, the green hexagon should blink indicating AF fail. When focus is attained, there should be a beep and the green hexagon should light.
I am curious as to what you mean by "moving the small wheel at the front of the lens all the way to the right". I have looked at illustrations of your lenses and the only thing I can see that is close to a "small wheel" is the focus ring. That should NEVER be turned by hand on an auto-focus lens when AF is turned on. Doing so can damage the AF drive in the lens and for screw-drive, the camera as well.
---------- Post added 12-02-14 at 08:29 PM ----------
QuoteOriginally posted by aleonx3 Quote
The position of the aperture ring does not affect the AF system.
af, aperture, auto, camera, distance, focus, k-7, k7, lens, lenses, light, light on distance, pentax, pentax help, pentax k7, shot, steve
Red Flares on K7 LCD when reviewing pictures Unregistered Visitors' Center 2 04-21-2012 09:10 PM
Any advice on snow shots with K7 vladm11 Troubleshooting and Beginner Help 15 12-24-2010 12:32 AM
Post your k7 low light high ISO shots Tony3d Pentax DSLR Discussion 2 10-21-2010 01:28 PM
Post your k7 low light high ISO shots raw Tony3d Pentax DSLR Discussion 14 10-19-2010 04:16 AM
blinking red light on my AF-540FGZ juicebox Pentax Camera and Field Accessories 4 07-21-2010 03:24 PM
All times are GMT -7. The time now is 09:57 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
