12-03-2014, 01:01 PM   #1
MBM
Guest
How to I change the shutter and aperture?
I have always taken simple photos with this camera but when I tried to take a picture in the dark the photo came out unfocused. I need help with changing the camera's aperture and shutter.
12-03-2014, 01:16 PM   #2
Na Horuk's Avatar
Hey, welcome! You can choose P mode and move the e-dial, which will shift the shutter and aperture, without affecting the brightness. Tv mode lets you choose the shutter speed, and the camera will do everything else. It is good to keep a shutter speed of at least 1/(2*focal length). So 50mm lens should be around 1/(2*50), which is 1/100. Shake reduction (SR) helps with that.
The other problem with dark scenes is Depth of Field. In dark photos, the aperture must be wide, but this causes the depth of field to be more shallow. If you shoot at f8, the depth of field will be very wide. But in darkness you need a smaller fnumber, like f2.8, which will cause the depth of field to be really shallow, perhaps only a couple centimeters. This means most of the photo will be unsharp.
So for dark photos it is best to raise the ISO (sensitivity), but this increases digital noise. Night time photography is a balancing act! With modern cameras, even very high ISO can be used.
Oh, one more thing. The camera will automatically keep a certain brightness of frames (automatic metering). You can affect this by the EV +/- button. But when there is not enough light, there is only so much you can do! This is why people use tripod (to keep photo still) and flash (to add light)
12-03-2014, 01:17 PM   #3
I think folks here would find it useful knowing which camera "this camera" is!?
You could also try reading the manual?
12-03-2014, 01:26 PM   #4
Otis Memorial Pentaxian
QuoteOriginally posted by Steve.Ledger Quote
Indeed, the manual is a great place to start.
The short answer to the question is that the two dials (rear and front) that fall under the thumb and forefinger are used to change aperture and shutter speed, respectively. (At least in the default configuration.)
12-03-2014, 01:35 PM   #5
aleonx3's Avatar
Ever try to convince a 5D MKIII user that he is missing a rear dial on his camera, and watch the expression on his/her face?
Ask also how to change ISO while keeping the eye in the viewfinder? (kind of awkward, have the use the same index finger to press and then, turn the front dial).
12-03-2014, 04:35 PM   #6
Imp
Imp's Avatar
QuoteOriginally posted by aleonx3 Quote
wait... 5dmkIIIs only have one dial???
12-03-2014, 05:28 PM   #7
aleonx3's Avatar
QuoteOriginally posted by Imp Quote
Don't think so, unless one can turn the wheel on the back of the camera to change value. I don't have the 5DmkIIIs, can someone confirm?
12-03-2014, 05:33 PM   #8
SpecialK's Avatar
There's a mkIII?
12-03-2014, 07:53 PM   #9
Adam_T4's Avatar
Manual
I printed out the online manual for my K20 and read it about 3 times before I even got the camera delivered!
12-03-2014, 08:50 PM   #10
aleonx3's Avatar
There's a mkIII?
I think they are up to MK III now... costs around 3k.
12-03-2014, 09:02 PM   #11
clackers's Avatar
You can.
12-03-2014, 09:14 PM   #12
aleonx3's Avatar
You can.
So, the wheel (vertical position on the back of the camera) is similar to the function of the rear dial? Rather awkward movement of the thumb reaching down to the wheel, but I guess once you get used to it, then it should be fine.
12-03-2014, 09:28 PM   #13
SpecialK's Avatar
Actually, rumors of a mkIV are starting...but I'll stick with the original for awhile :-)
12-03-2014, 09:34 PM   #14
aleonx3's Avatar
Since you have the 5D (original), so the big wheel on the back acts like a rear dial on the k-5, correct?
12-03-2014, 10:15 PM   #15
clackers's Avatar
Well, you see the guys turn it while looking down at the LCD on the top of the camera
Not my idea of ergononics, but there you go.
My NEX7 has three dials. The third is like the second Canon one, but it's only for ISO.
The K-S1 has the single dial and you hit the Exposure Comp button to toggle it between aperture and shutter.
camera, change the shutter, pentax help, shutter
how to change aperture on Kx? 4ngi3 Troubleshooting and Beginner Help 24 04-30-2014 11:10 PM
What is K-5II shutter resource and how much cost to change it ? Vejas Pentax K-5 & K-5 II 2 01-10-2014 03:05 PM
Using K10 In Manual Mode Aperture And Shutter Settings Change Suddenly Racer X 69 Pentax DSLR Discussion 9 10-21-2013 12:16 PM
Question How do I change the asking price in the marketplace forum? Dirk Site Suggestions and Help 6 09-23-2013 05:04 PM
How do you where to start with Aperture and SHutter speed?? hockmasm Pentax DSLR Discussion 22 05-04-2010 12:57 PM
All times are GMT -7. The time now is 04:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
