12-09-2014, 04:32 PM   #1
iwantamacrolens
Guest
Cheap Macro
What is a good macro lens that is cheap (Under 100$?) and has good quality?
MF is what I will use so old lenses that are easy enough to get are good as well.
Used is okay.
Prime lens is also fine :-)
I have a K-50 and want to shoot macro images.
I have the 18-55 and 50-200 kit lenses.
If I had NO budget I would have a K-3 with the 100mm WR Macro and 18-135mm WR, but there is a budget :-)
12-09-2014, 04:48 PM   #2
Docrwm's Avatar
M50 Macro is a nice lens, the M100 Macro is better but with some diligence you can often find them near your budget range. If you want to be more creative then some of the old F series zooms have a macro feature. They're often 1:4 or so when in Macro mode but the F35-70 is a terrific little lens and can be had for <$75 typically. Then there are the Sigma (Quantaray) brand 28-90 Macros that do a solid job for a zoom and they often go for around $50.
12-09-2014, 04:54 PM   #3
Pentax-M 100 f/4... has 1:2 magnification. It's a sharp lens. I found one for $85 dollars on ebay.
12-09-2014, 05:12 PM   #4
waterfall's Avatar
I have an A50, F2.8 macro that is a very sharp manual focus auto aperture lens. They can be pricey, up to $250 but can be found at $150 as well. Same optics as the F50 macro, supposedly, and one of the sharp 50 mm lenses. The M50 macro is similar sharpness I have read, without auto aperture, and can be found for around your $100 budget.
12-09-2014, 05:15 PM   #5
Na Horuk's Avatar
Welcome!
I think there are a couple threads about cheap macro. They offer nice solutions like buying bellows or extension tubes, reversing a lens, and so on. You can use a cheap M 50mm f1.7 with extension tubes or macro filters (raynox macro filters are really good)
12-09-2014, 06:33 PM   #6
baro-nite's Avatar
Consider a Raynox 150 to use on your DA50-200. The new price is around US$70, I think, but you should be able to find a used one for a fair bit less than that.
03-12-2015, 10:52 PM   #7
What about an extension tube or close up filters.
03-13-2015, 05:39 PM   #8
UncleVanya's Avatar
QuoteOriginally posted by Venom3300 Quote
Happy coincidence - there is one here on the marketplace for that same $ amount currently:
https://www.pentaxforums.com/forums/24-photographic-equipment-sale/288903-sal...acro-85-a.html
---------- Post added 03-13-15 at 08:43 PM ----------
Another option. Get an M42 adapter and some extension tubes and an enlarging lens and an M39 to M42 adapter ring.
https://www.pentaxforums.com/forums/177-macro-photography/285041-lightweight-macro.html
Or a reversing ring...
03-13-2015, 07:38 PM   #9
Aaron28's Avatar
close up filters are neat and a good way to start (for me anyways as I recently got them....the only fun I've been having with all this rain) plus they are super cheap.................prolly 49mm dia for the 50-200kit.....I got 52mm dia as most of my lenses are that size and a few with 'macro' feature
03-13-2015, 08:08 PM   #10
UncleVanya's Avatar
QuoteOriginally posted by Aaron28 Quote
52mm is the diameter of the 50-200. The Raynox CM-2000 Kit is just over 100 at B&H (use the forum links to get there) and offers a lot of flexibility.
03-13-2015, 08:46 PM   #11
Aaron28's Avatar
ok then reckon i'll scratch out the 49 that's on my 50-200 lens and put a 52 on it...............thanks for pointing that out
03-13-2015, 09:02 PM   #12
UncleVanya's Avatar
Which one do you have? SMC DA is 52, I'm confused.
SMC Pentax-DA 50-200mm F4-5.6 ED Reviews - DA Zoom Lenses - Pentax Lens Reviews & Lens Database
03-13-2015, 09:10 PM   #13
Aaron28's Avatar
the 50-200 kit that came with the k-50 smc/dal is on it.....I really do not know....it doesn't have the green on it like the one pictured in yer link
03-13-2015, 09:30 PM   #15
Aaron28's Avatar
qii-70-210......70mm @ f22 180s with flash and +4close up filter on K-r...not the best example of using a close up filter.......resized to 600 height.............the 50-200mm kit
PENTAX K-r  Photo
adapter, budget, camera, close, filters, lens, lenses, m42, macro, pentax help, wr
Macro Cheap Macro old4570 Post Your Photos! 3 07-04-2014 10:44 AM
Cheap (macro) lens kref Macro Photography 12 07-02-2014 07:21 AM
Suggest to me a cheap Macro option jezza323 Pentax SLR Lens Discussion 15 02-16-2014 04:16 PM
cheap macro kurt1968 Pentax SLR Lens Discussion 19 12-12-2013 10:47 AM
Cheap manual lens on cheap extension tube with cheap flash! Also cats. pasipasi Post Your Photos! 12 08-28-2008 04:43 PM
All times are GMT -7. The time now is 09:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
