Originally posted by dvelosky When I select the TAv mode on my K20D, rather than float, the ISO blinks at a set rate (200 or 400 based on the D-Range setting). Adjustment of the shutter speed and/or aperture has no effect. Am I missing some internal setting somewhere?
In TAv mode, you control the Aperture and Shutter speed and the camera adjusts the ISO to get a "correct" exposure. When a setting blinks, like your ISO, it means that the "correct" exposure is not possible with the current settings. In your circumstance, the ISO wants to go lower to get a correct exposure, but it can't (due to D-Range stuff), so it blinks to tell you it can't get the "correct" exposure. The situation is too bright for ISO 200 or 400. This is usually due to setting the aperture wide open, for instance, using f/1.8 on the 50mm f/1.8 lens, or using a long shutter speed, like 1 second or longer. There just is too much light coming in with those chosen A and T settings.
