02-17-2015, 08:48 AM   #1
BJB
Guest
Blue cast
I have a new K50 with the standard 18-55 lens. My photos are coming out bright blue - the colour of skies and sheets of water (and our front door) is really distorted. If there is nothing blue on the picture I'm taking the colours seem accurate, though a bit bright for my taste. Have I set something wrong or is there a fault on the camera?
02-17-2015, 08:52 AM   #2
enoeske's Avatar
QuoteOriginally posted by BJB Quote
Sounds like you have the white balance set incorrectly.
02-17-2015, 08:57 AM   #3
You camera supports several different JPEG modes. A few of those are fairly garish and it is possible you have accidentally set your camera to one of those. See page 157 in your manual. As noted above, you might also have the white balance set to other than Auto.
02-17-2015, 09:21 AM   #4
BJB
Guest
Thank you
What prompt replies. I'll get on to that straight away.
02-17-2015, 09:29 AM   #5
aleonx3's Avatar
It sounds like you may have set the WB to tungsten (usually for indoor lighting) and forgot about it. Some people do that, but most would keep it at auto-WB.
camera, pentax help
PP for RAW taken from jetliner (blue cast) LensBeginner Digital Processing, Software, and Printing 3 12-16-2014 12:16 PM
Blue cast using M prime lenses on K500 martbev Welcomes and Introductions 11 06-23-2014 04:07 PM
About WG-3 Blue cast underwater ?? photoshoper Pentax Compact Cameras 3 09-03-2013 03:54 AM
Lightroom - remove blue cast Sigma 24mm f2.8 Super-Wide II Phillean Digital Processing, Software, and Printing 6 03-01-2013 01:27 AM
Provia 100F - Removing blue color cast adelorenzo Film Processing, Scanning, and Darkroom 18 02-20-2012 02:31 PM
All times are GMT -7. The time now is 11:02 PM. | See also: NikonForums.com, part of our network of photo forums!
