03-20-2015, 10:57 PM   #1
Ever G
Guest
Can't see a thing through the Pentax kx view finder
I noticed today that I couldn't see through the view finder of my KX. I did remove the lens and noticed that the mirall is not dropping enough seems like it's stuck (not sure). I tried to gently move it but couldn't get unstuck it. Any advice will be appreciated.
03-21-2015, 01:30 AM   #2
Do you have the KX film camera or the K-x dSLR?
03-23-2015, 05:47 AM   #3
Na Horuk's Avatar
If it is the digital K-x: remove battery. charge it. leave it outside of camera overnight. test it to see if battery works. try again.
Do you have AA battery adapter? You can try that. I suspect the problem might be the battery.
If you are talking about the older film KX camera, I don't know.
« X5 novice | aroura »
camera, finder, kx, pentax help, pentax kx view, view
Can't see through Pentax 645 viewfinder lgunders Troubleshooting and Beginner Help 2 10-13-2014 02:17 PM
Moire in view finder only and fuzzy look through view finder Indy78 Troubleshooting and Beginner Help 13 06-11-2014 11:36 AM
cant see anything through my view finder of Pentax K1000 MRP1 Visitors' Center 7 02-14-2014 09:38 PM
Can you see a TLR finder in bright light? sewebster Photographic Technique 6 02-15-2011 07:47 PM
New Zealand through the view finder. Pt 1. Mallee Boy Post Your Photos! 4 05-17-2008 05:01 PM
All times are GMT -7. The time now is 01:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
