06-15-2015, 01:22 PM   #1
Savage1
Guest
ist d-will not go to menu
Hello-I have an IST D that does not seem to be working correctly. I have replaced the main and backup batteries. When I turn the camera on it goes to the setup screen for date/time etc. In this mode I am unable to move the cursor or make any settings. I should be able to skip this by pushing the Menu button which should put it in shoot mode, but this does not work either. It seems the other adjustments and buttons are all working-I just cant get out of the set date and time screen--any ideas?
06-15-2015, 03:31 PM   #2
stillshot2's Avatar
Try removing the battery, turn the power switch to on, and hold the shutter button down for a minute or so. This usually drains all capacitors or small internal batteries within the camera for some models of DSLR cameras, but I am not entirely sure if it will work for your specific Pentax. It may worth a try, since this trick would work on Sony DSLRs.
08-17-2020, 04:26 AM   #3
Same problem exactly????
ist D has worked flawlessly since purchased new - now presents with exact symptoms of OP in this thread.
Hello-I have an IST D that does not seem to be working correctly. I have replaced the main and backup batteries. When I turn the camera on it goes to the setup screen for date/time etc. In this mode I am unable to move the cursor or make any settings. I should be able to skip this by pushing the Menu button which should put it in shoot mode, but this does not work either. It seems the other adjustments and buttons are all working-I just cant get out of the set date and time screen--any ideas?"
New batteries, including memory backup battery, even swapped lenses "in case" - no joy.
Tried the batteries out and holding down the shutter button - no joy.
Has anyone found an answer to this??
08-18-2020, 05:21 AM   #4
QuoteOriginally posted by PeterDohnt Quote
The *istD cameras have a reputation for being "fussy" about which batteries will work reliably or for any length of time.
The "favourite" seems to be 'eneloop' NiMH rechargeables, which I use in my cameras with no problems, but non-rechargeable Lithium batteries are also recommended by many.
"Ordinary" alkaline batteries seem to cause the most problems.
Hope this helps
08-18-2020, 09:21 PM   #5
I was just about to list my working 1st D for sale, with a parts 1st D and a Pentax battery pack. PM if interested...
camera, menu, mode, pentax help
Flash will not go into P-TTL mode siric Troubleshooting and Beginner Help 6 08-09-2015 02:34 PM
My Mirror Will Not Go Down photographyguy74 Non-Pentax Cameras: Canon, Nikon, etc. 5 01-24-2014 04:21 PM
ist D + Mac + Remote Assistant = no go! Please help me... Pentaxke Pentax Camera and Field Accessories 9 10-28-2013 01:34 AM
K5ii will not go below 200iso moresnowdays Troubleshooting and Beginner Help 9 07-13-2013 06:07 PM
Help! My lens will not go down to f1.7! BEENS Pentax SLR Lens Discussion 2 10-15-2010 04:37 PM
All times are GMT -7. The time now is 09:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
