Originally posted by Type3 Thanks for replying. Sounds like it isn't a battery issue then. I have to take the batteries out sometimes too to turn it off, but often if I turn it straight back on it will still flicker and I'll be lucky to get 1 or 2 shots before it freezes up again. Some days however I can get a dozen or 2 dozen shots where everything seems fine, then it's suddenly stops again. It seems to go wrong more when in playback mode for reviewing captured images, so I've stopped it going to review after taking an image, but that only works sometimes however. I can only imagine that playback mode requires more power and this is where the camera's fault lies, somewhere to do with not being able to maintain a steady high enough power outage; but that feeling is from someone who is far from an electrician!
Yeah, The only problem with my camera is that is has is the screen will have those weird lines and sometimes the screen goes completely blank. I usually just take batteries out and put them back in and the problem is solved. like I said this is really intermittent, but it maybe because I am using eneloops?? You may try specifying the actual battery type "Select Battery Type" in the menu. I think the default is 'auto' detect, but you can specify alkaline or lithium...
Hope you get your problem resolved.
