09-03-2015, 01:09 AM   #1
Mare
Guest
pentax 67 - asa
Hi, I just got my first medium format camera pentax 67, but where the hell do I set the asa? every manual says lift the shutter dial, but mine cant.
please help, feeling really stupid!
09-03-2015, 01:18 AM   #2
You should be able to just lift the outer ring of the shutter dial, then turn it and let it drop again.
09-03-2015, 01:48 AM   #3
Mare
Guest
hi Adam, there is no outer ring. just one solid knob for shutter speed
09-03-2015, 02:29 AM   #4
UncleVanya's Avatar
No meter?
09-03-2015, 02:43 AM   #5
Is it like this: PENTAX 67 Pentaprism Finder reviews - Pentax Camera Accessory Review Database (no meter)
Or like time: PENTAX 67 TTL Pentaprism Finder reviews - Pentax Camera Accessory Review Database (TTL meter) ?
09-03-2015, 02:49 AM   #6
it is the pentaprism, no meter
09-03-2015, 04:38 AM   #7
UncleVanya's Avatar
QuoteOriginally posted by maree Quote
Can you use another camera to meter for now?
09-03-2015, 05:31 AM   #8
TaoMaas's Avatar
Then it doesn't care what the ASA is. You'll have to use something else to meter the exposure. You can use a hand-held meter or, like UncleVanya suggested, use another camera to meter the scene.
Edited to add: Setting the ASA on a camera is only done to let the internal light meter know what kind of film you're using.
09-05-2015, 12:45 PM - 1 Like   #9
Mare, for further questions on the 67 series of cameras, please be aware that there is a forum within Pentax Forums dedicated to just those cameras.
Heavy Pentax - for 6X7 format users - PentaxForums.com
09-06-2015, 08:57 PM   #10
hks_kansei's Avatar
As above, only cameras with some form of metering need the film speed set, the 6x7 and 67 dont have meters built in (although a metered prism was available)
you will need to do one of the following:
1: Learn the Sunny16 rules, and estimate exposure by eye.
2: Download and use a light meter application on your phone.
3: Purchase a handheld light meter
4: Purchase a Metered prism for the 67
The phone suggestion is ok, but depends on how good the metering in your phone is.... usually not very good.
For me I'd strongly suggest learning Sunny16, it's free, and once you've memorised a few rules it means you know enough to still shoot cameras even if the batteries for the meter run out.
edit:
Bearing in mind that the handheld meter or the metered prism will be more accurate than Sunny16, so if accuracy is super important buy a meter,
asa, camera, pentax, pentax help
Pentax K1000 and ASA dial problem Pentax1000 Troubleshooting and Beginner Help 5 10-02-2014 07:55 AM
67 lens with 67 extension tubes on 645d fatboy22 Pentax Medium Format 3 06-28-2014 04:44 PM
duda asa y flash pentax k1000 mery Visitors' Center 2 08-15-2011 03:18 PM
All times are GMT -7. The time now is 02:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
