10-22-2015, 01:58 PM   #1
shinya
Guest
Lens hood selection
Question. I am using older Pentax A lens, 50mm 1.7 and 35mm 2.8, on digital k-x camera. When selecting lens hoods will the old stock corresponding Pentax work OK? or will there be vignetting of image due to cropped sensor size? The 50mm translates to 75mm on APS C, no?, will the hood not be affected by this?
10-22-2015, 02:28 PM   #2
The original lens hoods will work just fine.
The field of view of the lens stays the same, used on film, APS-C crop size sensor, or full frame sensor. So there will be no vignetting of the image if the original hood is used on the lens it was meant for.
10-22-2015, 02:43 PM   #3
I wonder if the film era hoods are not narrow enough on the crop sensor bodies?
10-22-2015, 02:56 PM - 1 Like   #4
UncleVanya's Avatar
QuoteOriginally posted by yucatanPentax Quote
True but the field of view you capture changes so you can get away with using tighter and longer hoods. I recently tested a 49mm Takumar hood designed for the 135 f/3.5 and 200mm f/5.6 on my F 50mm f/1.7 and found no noticeable vignetting - some minor vignetting may exist, but none I can detect. I would recommend hoods designed for the "equivalent focal length" rather than those as long as I am using as a shortcut to something a bit more effective than the original hood. The original hood however will work no worse than it ever did on film.
10-22-2015, 04:39 PM   #5
boriscleto's Avatar
I use a generic 49mm Telephoto lens hood on the FA 50/1.7. No vignetting and that lens has a recessed front element.
10-27-2015, 10:57 PM   #6
shinya
Guest
Thank you for quite a selection of input! I believe this requires some degree of experimentation, perhaps a hood that is of the "equivalent focal length" is a good bet. Somewhere between the original issue and equivalent focal length is maybe OK.
10-29-2015, 03:09 PM   #7
QuoteOriginally posted by woodywesty Quote
On the wide end (say 35mm focal length and shorter), this is most definitely the case. They are adequate in that they shade the front element from oblique light the same as when used for 35mm film, but may benefit from a deeper hood on the cropped format.
QuoteOriginally posted by boriscleto Quote
I do the same. The hood I use with my 50mm lenses is the generic round metal hood (telephoto) from Heavystar on eBay. The hood will also accept a 58mm pinch cap at its opening. I use the 49mm version on my M and A series 50/1.7, FA 77/1.8 Limited, and LZOS Jupiter-9 85/2. The 52mm version works well on my K 55/1.8 and DA 50/1.8.
New! Metal Tele 49mm Screw-in Lens Hood
(Not affiliated with heavystar or any other eBay merchant.)
50mm, camera, hood, lens, lens hood, pentax, pentax help
help with camera/lens selection Dustoff Troubleshooting and Beginner Help 8 08-23-2015 07:01 PM
DA* 50-135mm lens hood replacement - would a Canon hood fit!? kp0c Pentax SLR Lens Discussion 6 02-05-2015 07:28 PM
Help with 645Z lens selection Haseebmunir Pentax Medium Format 3 07-15-2014 06:11 PM
Another lens selection help thread auricle Pentax SLR Lens Discussion 9 06-29-2014 02:34 AM
Lens selection question for gift budm Troubleshooting and Beginner Help 8 11-15-2013 04:41 AM
All times are GMT -7. The time now is 09:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
