11-03-2015, 11:49 AM   #1
Jonny M
Guest
over-tightened rewind crank?!
Hi all,
I have bought an old Pentax mx, had great fun using it for a few film rolls and now seemed to have broken it and hoping to find out how I can fix it! I was rewinding a film, the crank gradually became harder to turn but I thought this was probably normal as more and more film was wound into the canister. But in the end it became impossible to rotate it any further - seems I've over-tightened it If I try turning the crank the other way (anti-clockwise) it just unscrews from the small thread. The crank wont lift up to release the back door. Any ideas?! Thanks!
11-03-2015, 12:19 PM   #2
Senior Moderator
Parallax's Avatar
Can you advance the film?
11-03-2015, 02:17 PM   #3
Jonny M
Guest
Yep no problem there..
11-03-2015, 02:56 PM   #4
Senior Moderator
Parallax's Avatar
Well, if you can advance the film after a shot but pushing the rewind button on the bottom doesn't disengage it, I'm stumped. Hopefully someone who can actually help will be along soon.
11-04-2015, 06:06 AM   #5
Are you sure the rewind button hasn't sprung out again by itself?
I remember in my film days this happened occasionally during rewinding.
I think I also had one body where I had to keep it pressed down all the time (during rewinding).
11-04-2015, 09:34 AM   #6
QuoteOriginally posted by Parallax Quote
QuoteOriginally posted by RKKS08 Quote
You did push the small rewind "release" button on the bottom of the camera, right?
11-20-2015, 09:52 AM   #7
Jonny M`
Guest
Hi guys thanks for your comments, after reading them I fiddled around with the release button some more and think it had been sticking/not releasing properly, but sufficient force/fiddling seemed to do the trick!! sorry it took so long to post a thank you!
Jonny
camera, crank, film, over-tightened rewind, pentax help
ME Super film rewind crank came off! chiaroscuro Troubleshooting and Beginner Help 2 04-29-2015 03:45 PM
Help with broken rewind crank on K1000 [urgent] RotisserieChicken Pentax Film SLR Discussion 9 04-13-2012 10:29 PM
Pentax Me Super: lost the rewind crank zerotonothing Pentax Film SLR Discussion 12 12-28-2011 09:00 PM
Pentax ME (not Super) crank/rewind problem Adnan87 Troubleshooting and Beginner Help 3 11-25-2010 10:07 AM
ME Super help - no film advance crank tension, rewind button stuck mclean8 Pentax Film SLR Discussion 2 11-06-2009 07:27 PM
All times are GMT -7. The time now is 06:22 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
