03-09-2016, 09:36 PM   #1
MikeDHolm
Guest
Pentax Optio S4i Blurry photos with small items, for example print
I have an older Pentax. It is an Optio S4i. I'm not sure why it will not zoom in and focus well on smaller items. Smaller items including print on items will be blurry in the photos. Is there something that I can do to get this camera to focus better on smaller items. It focuses well on larger items however when I need to zoom in and focus, I have the problem. Thanks for any help you can offer.
03-09-2016, 09:56 PM   #2
jatrax's Avatar
Just a thought, but are you sure you are not too close? Most cameras have a minimum focusing distance, if you get closer than that they cannot focus.
03-12-2016, 03:38 PM   #3
I used to own an Optio S4i, and I think the usage is the same as with my 2 Optio S5i cameras.
If AF is able to focus correctly, there will be a GREEN frame visible in the AF area on the display.
If not (too near or too dark), it may be RED (or no frame at all visible).
The Optio S5i (and, as far as I remember, the S4i) has several settings to handle focusing (set by repeatedly pressing the button left from the zooming "button)".
The options are: MF (AF disabled, setting distance using a numbered scale then visible on he screen), landscape AF, near and macro.
For close focus you have to use near or very near (=macro).
In standard (landscape) the autofocus will not focus much nearer than 70-80cm. But you will see that on the display, as no green frame will appear.
camera, focus, optio, pentax, pentax help, pentax optio s4i, photos, print, s4i, s4i blurry photos
soft/blurry photos below f8 with SMC Pentax-DA 18-55mm F3.5-5.6 AL II Capslock118 Troubleshooting and Beginner Help 21 11-26-2015 02:55 AM
Technique for capturing Photos for HDR- Blurry photos jaywes Troubleshooting and Beginner Help 15 10-28-2015 06:45 PM
Question How to display photos of items for sale Richjac Site Suggestions and Help 4 06-13-2014 03:09 AM
Windows 7 USB driver for Optio S4i HappySnapper Pentax Compact Cameras 6 10-18-2011 05:30 PM
All times are GMT -7. The time now is 07:45 AM. | See also: NikonForums.com, part of our network of photo forums!
