05-15-2016, 12:59 PM   #1
chris bruce
Guest
pentax istD firmware update?
When it says update firmware so you can use a sdhc card - will the regular SD cards still work? Is this firmware update and update to my camera or the sdhc card?
05-15-2016, 01:34 PM   #2
ramseybuckeye's Avatar
Firmware updates are to your camera, and I would think you could still use SD cards, I've never heard of an update that would disable something like that without telling you first.
05-15-2016, 02:05 PM - 1 Like   #3
dave kitson's Avatar
It's been a while, but I'm sure that my istD used Compact Flash cards, not SD.
davek
05-15-2016, 02:12 PM   #4
RobA_Oz's Avatar
The *istD uses Compact Flash (CF) memory cards, not SD cards. The subsequent models (*istDL, DS etc) use SD cards. The last firmware update for the *istD was 1.12. Don't try to install an update for the wrong model.
05-16-2016, 09:32 AM   #5
Update
QuoteOriginally posted by chris bruce Quote
I did it, it works with all smaller Cards too
05-16-2016, 11:28 AM   #6
Firmware updates can be carried out with any memory card that the camera supports.
Older models added SDHC or SDXC support via firmware, in which case you need to use an SD or SDHC card, respectively.
But yeah, the ist D uses compact flash cards.
05-16-2016, 08:18 PM   #7
UncleVanya's Avatar
SDHC is an added spec - it does not remove the SD capability. I had an *ist DS that I had to do this to - luckily I had a 1GB card to do it from and it worked great.
05-17-2016, 12:14 AM   #8
Agree. Probably Bruce has an istDs, as I do.
05-22-2016, 04:35 PM   #9
Na Horuk's Avatar
So, to sum up:
a) Make sure you get the firmware update for exactly the right camera model that you have. Also, be careful of the language, so you don't update into a language that you don't understand (has happened before, I think)
b) Firmware update only expands compatibility. It does not remove regular SD card compatibility, those will work just as well. It only adds SD HC, SD XC or whatever they are called.
There are many tutorial threads, even a PF front page article and youtube video about how to carry out a firmware update. Make sure you use a fully charged, reliable battery. Good luck
camera, card, firmware, pentax help, pentax istd firmware, sdhc
Update firmware pentax k100d keith young Visitors' Center 2 12-27-2015 11:28 AM
how to update firmware for Pentax ist DL2 lpa0304 Pentax DSLR Discussion 2 06-02-2015 11:39 AM
Firmware Update for Pentax FluCard O-FC1 Stone G. Pentax News and Rumors 4 09-11-2014 06:55 AM
Should i update pentax k-5II firmware ? Vejas Pentax K-5 8 09-09-2014 04:59 AM
Help! Pentax Q10: Firmware update menu selection TofuTO Pentax Q 3 08-18-2014 05:47 PM
All times are GMT -7. The time now is 11:04 AM. | See also: NikonForums.com, part of our network of photo forums!
