06-04-2016, 08:03 AM   #1
Martin__
Guest
Pentax-K1, Playback: Is it possible to switch Images if zoomed in?
Hi,
I have studied the K-1 manual, but could not find any hint if it is possible in playback to "jump" from image to image if zoomed in.
Most cameras I know (Canon, Nikon, Pentax K-30) do have this feature, but not my Pentax K-01.
So does anybody know if the K-1 can do this?
Thanks,
Martin
06-04-2016, 08:10 AM   #2
bertwert's Avatar
I don't have a K-1, but I'll suggest trying the front E-dial.
Do you have a K-1 or K-01?
06-04-2016, 08:18 AM   #3
Martin__
Guest
Hi,
I have the Pentax K-01 and the K-30 only.
And the manual of K-30 does describe this feature.
But the K-01 and the K-1 manual do not.
So maybe a K-1 user can tell if this feature is available.
Best regards,
Martin
06-04-2016, 08:30 AM   #4
bertwert's Avatar
Ok.
Since the K-01 only has one e-dial I am not sure if this feature is possible.
As all other Pentax models use the back to zoom and the front one to change photos.
06-04-2016, 08:44 AM   #5
Martin__
Guest
I hope and think you are right.
But the strange thing is that the K-30 manual describes this feature in detail, but the K-1 manual does not.
Best regards,
Martin
06-04-2016, 09:22 AM   #6
Topsy's Avatar
The K-1 behaves the same as the K-50, I'm sure I would have noticed otherwise.
06-04-2016, 09:49 AM - 1 Like   #7
wtlwdwgn's Avatar
Yep, the front e-dial will move to the next image.
06-04-2016, 12:38 PM   #8
Martin__
Guest
Ok, thank you all!
I just took a look to the k-50 manual and it says:
"Front e-dial (R)
Retains the magnification and the
position of the display area and shows
the previous/next image."
The same as my K-30 manual says.
So I asume, as "Topsy" says, the K-1 behaves the same.
(Just strange that these lines are missing in the K-1 manual.)
Thanks,
Martin
camera, image, k-1, pentax, pentax help, playback
K1 interface, how is it meant to be used? biz-engineer Pentax K-1 9 05-19-2016 07:08 AM
Is it worth it to switch to K-5 II for the sake of ultrasonic dust removal? rrstuff Pentax DSLR Discussion 13 12-26-2013 05:53 AM
Is it possible to use manual flash in TAv mode? ismaelg Pentax DSLR Discussion 3 07-09-2013 11:52 AM
Is it possible to fix my in-camera flash?(k10d) Akiou Troubleshooting and Beginner Help 7 01-17-2010 09:25 AM
Is it possible to have an electronic range finder feature in future Pentax DSLR? fearview Pentax News and Rumors 13 04-01-2009 05:15 AM
All times are GMT -7. The time now is 05:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
