Originally posted by gmans Use the DOF preview button to test the aperture stop down is working, it's on the shutter button turn it to the right on the K3.
it operates the same way on K-1 as it does on
K-3.
When DoF preview is set to Optical Preview in Camera | 5 | Preview Dial, pull the DoF preview lever (the On/Off ring surrounding the shutter release button) to the right and hold. The camera will stop down the lens and you can observe the DoF through the viewfinder.
This action will also meter the scene. I sometimes prefer metering with the DoF Preview lever rather than the Green Button using a manual lens since I use the AF button on the back of the body rather than half-press; I would need to move my thumb to GB meter. I press the AF button to obtain focus confirmation, then trim focus if necessary.
