Originally posted by Iggy Tavares Hi UncleVayna, Thank you for the immediate and very comprehensive reply, with every thing so well explained, which is much appreciated. How does the ist DL2 sensor compare with the K100D or even the Canon 70D in size and quality?
I will put a new battery into my Z-20 to check out if the Macro lens is still functioning smoothly, not having used the pair for over a dozen years. Thanks again, Iggy
I honestly don't know the answer on the sensor. I used an *istDS briefly recently (within the last year) and a K100D and K100D super are in my "collection" so I'm pretty familiar with them. They all used a 6mp sensor that was fairly similar I thought but the processing engine and autofocus on the K100D series might be improved. I'd look here:
Pentax K-mount DSLRs - Pentax Pentax Digital Cameras - Pentax Camera Reviews and Specifications for reviews and info. A quick glance:
*istDL2:
The Pentax * ist DL2 resembles the *istDS2 but was offered at a lower price point made possible by replacing the pentaprism with a pentamirror and removing some features, hereunder TTL flash support and display of the active AF point in the viewfinder. The *istDL2 was only offered in select markets. Compared to the *istDL, the DL2 has electronic preview in addition to optical depth of field preview, and it has 5 autofocus points rather than 3.
Read more at:
Pentax *ist DL2 - Pentax K-mount DSLRs - Pentax Camera Reviews and Specifications
K100D:
The 6 MP K100D is a very capable camera and introduced in-camera shake reduction to the entry level cameras back in 2006. The shake reduction works with all lenses, new as well as old. The K100D shares most of its technical data with the *istDS2 but in order to be able to reduce its price Pentax removed TTL flash support and changed the viewfinder from a pentaprism with 0.95x magnification to a pentamirror with 0.85x magnification. As a consequence the viewfinder looks smaller and darker than the viewfinder of the *istDS2.
Operating Manual
Read more at:
Pentax K100D - Pentax K-mount DSLRs - Pentax Camera Reviews and Specifications
So honestly after reading those summaries I would suspect the K100D and *istDL2 are very similar. Both have PentaMirror, both include a 6mp sensor, and both lack TTL flash support. The IBIS (In body Image Stabilization) of the K100D is a very nice to have feature but not essential. The ISO performance of both cameras is pretty weak and the IBIS helps offset that on the K100D. Neither camera will work with SDM only lenses like the DA 17-70 or DC lenses like the 18-135. The K100D Super is the low end body that adds SDM support.
