09-27-2016, 12:06 AM   #1
Mark 2112
Guest
K-7 Memory Cards - Largest Size that can be used - Firmware update?
I just got a New K-7... (well New to me, and only 1400 Shutter Clicks.)
- I can Not find Any info Anywhere about the Largest Size Card in GB I can use in this Camera.
Not in the Maunal, Not at the Ricoh Website, and Not here either... been searching threads for Hours...
Seems to me this should be on the second page of the Manual, but Not there... Only info you get is How Many Images you can store on a 4gb SD card.
(Please tell me I can use something Larger than a 4gb SD card)
Do I need a Firmware Update to use Larger SD Cards? - - (Firmware on this K-7 Camera has Not been updated)
I also read a thread here about some guy Killing his K-7 with a Firmware update... Anything I need to know?
Any Help would be Great, Thanks
09-27-2016, 12:17 AM   #2
With firmware version 1.11 or newer, the K-7 can use any SDXC, SDHC, or SD card. The largest SDXC card currently on the market has a capacity of 512Gb, but the standard has a theoretical maximum of 2048Gb (2Tb), and such cards will work with the K-7 once they are released.
Prior to firmware version 1.10, you could only use SDHC and SD cards. SDHC cards go up to 32Gb and one would be needed to perform the update.
Given the K-7's 14-megapixel resolution, I'd say you'd be fine using a 32Gb or 64Gb card. A high-performance 32Gb SDHC card only runs about $15 these days, so that'll be your best value.
See also:
Comprehensive SD Card Guide for Photographers - Articles and Tips | PentaxForums.com
09-27-2016, 12:21 AM   #3
pjv
pjv's Avatar
Hi Mark. There are some threads on the forums that say the K-7 will need a firmware update to take bigger storage cards. As far as killing a camera with an update, the damage is usually done by not having a fully charged battery, or turning off the camera before the update is complete. Here is a link for you about Pentax firmware updates. Good luck.
09-27-2016, 12:59 AM   #4
p38arover's Avatar
I use 32GB max - that's more than enough to lose when it goes bad.
camera, card, cards, cards largest size, firmware, k-7, k-7 memory cards, pentax help, sd, size
Can Both Memory cards in K3II be set to Raw? mhsp Troubleshooting and Beginner Help 9 11-28-2015 09:07 AM
K-3 tethering may be coming via a firmware update Adam Pentax K-3 28 09-15-2015 02:33 AM
Focus peaking can be done through firmware update? LFLee Pentax DSLR Discussion 22 09-21-2012 05:34 PM
ist DL and New Firmware - Largest Memory Card? iamnaeth Pentax DSLR Discussion 2 05-06-2010 06:28 PM
What's the largest size I can print photos from k-x? hockmasm Pentax DSLR Discussion 11 05-05-2010 12:04 PM
All times are GMT -7. The time now is 05:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
