10-18-2016, 05:24 PM   #1
DrRae69
Guest
My menu will not stay on long enough to scroll through
I cannot change my White Balance. When I push the button it immediately flashes off, there is no time to change it. When I go to the menu it also immediately flashes off, there's no time to scroll through. Did I accidentally change some timer option that would normally allow me plenty of time to change my options? I cannot figure this out or find help in the manual or elsewhere online.
10-18-2016, 05:30 PM   #2
photolady95's Avatar
Location: Cruising PentaxForums and watching your back.
Would help if you told which camera?
10-18-2016, 05:38 PM   #3
Senior Moderator
Nass's Avatar
Hello DrRae69, and welcome!
Unfortunately this sounds like a camera repair job to me, it isn't normal behaviour. When I press the WB button on any of my Pentax cameras, the back LCD changes to a "Color Temperature" screen and doesn't change until I press ok again in the centre of the 5 button dial.
Regards,
-Nass
10-18-2016, 06:09 PM   #4
Could be a stuck button, for example the shutter button half-press, which normally pulls you out of the menus.
10-18-2016, 06:19 PM   #5
pjv
pjv's Avatar
Do you have a battery grip attached to your camera, and if so, is it turned on? Touching the battery grip shutter button while holding the camera will also turn the menu screen off. Good luck.
camera, change, flashes, menu, pentax help, scroll, time
Do you feel the K-50 mount is strong enough to support big lens on tripod 4 long? fstop18 Pentax K-30 & K-50 7 09-09-2016 12:48 PM
How long will the current K-1 stay in production until they come out with new model ? Dlanor Sekao Pentax DSLR Discussion 31 09-04-2016 06:52 AM
Q7 SD Card will not stay in blackcloudbrew Pentax Q 21 05-11-2015 09:08 AM
SD Card will not stay in RParks Pentax DSLR Discussion 7 08-02-2010 02:35 PM
P30T, shutter will not reliably stay open on bulb with cable shutter control. skid2964 Pentax Film SLR Discussion 6 06-09-2008 08:04 AM
All times are GMT -7. The time now is 05:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
