08-20-2017, 07:38 AM   #1
Cristian Albornoz
Guest
Transferencia de fotos a PC (Transfer photos to PC)
Me regalaron una camara PENTAX Kx y no me entregaron el disco de instalacion en la PC, donde puedo obtener los drivers y cuales son los necesarios para poder ver mis fotos.-
Gracias.
Google translation (added by moderator):
I was given a PENTAX Kx camera and they did not give me the installation disk in the PC, where I can get the drivers and what are the necessary ones to be able to see my photos.-
Thank you.
08-20-2017, 10:17 AM   #2
Senior Moderator
BigMackCam's Avatar
Hello Cristian, and welcome to the forums. I'm sure some of our members should be able to advise you
Please note, our forum rules require that all posts are in English, or accompanied by an English translation. I've added one to your post.
Good luck!
08-20-2017, 04:50 PM   #3
35mmfilmfan's Avatar
AFAIK, all you need to do is copy the photos from the card to a folder on your computer using a USB card reader - the OS takes care of the rest, unless you want to edit the images, in which case image editing software will be necessary as well.
HTH
08-20-2017, 06:34 PM   #4
As was said, the SD card from your camera can be inserted into a usb type SD card reader, and when that reader is inserted into your computer usb port you can move files from the SD card to your computer. Also, a useful free editing software called Google Nik Collection is available if you are in need of an image editor (shortcut below).
camera, fotos a pc, los, pc, pentax help, transferencia de fotos
Pentax km - Sensor cubierto.. no puedo hacer fotos agil Troubleshooting and Beginner Help 8 06-23-2011 08:32 AM
Fotos de la K7 negras al editar con PENTAX Digital Camera U yuqui Troubleshooting and Beginner Help 10 02-15-2011 06:44 PM
Misc Fotos mit HDR- und Filtertechnik meermike Post Your Photos! 23 01-11-2011 01:53 PM
Cuantas fotos lleva la camara scastilloc Pentax K-r 3 12-16-2010 11:52 PM
Some Fotos from my new K10D afelix Post Your Photos! 3 03-21-2007 09:28 AM
All times are GMT -7. The time now is 01:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
