03-10-2018, 05:26 PM   #1
Dean Knudsen
Guest
istDL internal battery replacement
Does istDL have internal battery that needs to be changed? If so, how often and how easy is this procedure?
03-10-2018, 06:30 PM - 1 Like   #2
photoptimist's Avatar
If the camera is still retaining the time and date when you swap batteries, the internal battery is fine.
Replacing the internal battery is not easy -- it's likely to be soldered on to the main circuit board.
Last edited by photoptimist; 03-12-2018 at 07:06 PM. Reason: corrected a correction (thanks stihlmania!)
03-10-2018, 07:22 PM   #3
paulh's Avatar
Not sure about the DL, but my ist D uses a 2016 cell for keeping date and time. There's a small circular door on the bottom that retains the cell.
03-10-2018, 07:24 PM - 2 Likes   #4
maw
maw's Avatar
Hi Dean,
I think you refer to the buffer battery, which is on the bottom of the camera, (I own the *istD), I think the function is equal to the DL,
You need to replace the battery with a Lithium CR2016 (or similar) which is needed to keep the camera updated, the Date, and maybe other parameters.
The duration is variable depending on how new the battery is, but a few years certainly, the procedure is very simple.
Let me know if it is the one you are referring to.
03-12-2018, 06:24 PM - 1 Like   #5
Replacing the internal battery is not easy -- it's likely to be soldered on to the main circuit board. -- see maw's answer.
The 1st DL and 1st DS both have the memory battery internally mounted on the main board, the 1st D has a replaceable memory battery on the bottom center of the camera.
03-12-2018, 08:25 PM - 1 Like   #6
maw
maw's Avatar
QuoteOriginally posted by First Poster Quote
Hi Dean,
1) If the date and time are working, you don't have to worry, see page 25 of the manual, it is written that you need to use the CR-V3 or Lithium Battery or AA Alkaline batteries for power supply.
2) If you do not see the correct date and time at power on, the problem It is almost certainly due to internal power supply, in which case you will have to send it to a service center, I think.
If you can tell us how exactly is the situation.
03-18-2018, 05:41 AM   #7
forensicscientist's Avatar
As others have noted before me.....the ist-D uses a 2016 coin type battery, and is accessed on the bottom of the camera.
The ist-DL does not use a battery, but rather a capacitor to retain / provide power to the camera when the main batteries are either dead, or being replaced by the user. If the date and time change when you replace the main batteries (AA's) then you'll need to either open up the camera and replace this capacitor (not easy) or simply live with the issue.
I will point out that the capacitor was never designed to be replaced by the user....however, it can be done. Getting the camera back together afterwards is probably the most difficult part of the procedure.
battery, camera, istdl, istdl internal battery, pentax help
K-30 internal battery / capacitor replacement for clock ekip Pentax K-30 & K-50 47 07-19-2021 02:17 PM
Should I worry bout internal battery being dead in a Q10? kb244 Troubleshooting and Beginner Help 11 10-11-2020 08:15 AM
internal battery dead? have to set date hawli Pentax K-r 8 09-26-2014 01:00 AM
istDL battery problem sonofknute Troubleshooting and Beginner Help 15 12-22-2012 08:24 AM
K5 internal battery 1923loar Pentax K-5 & K-5 II 9 05-13-2012 09:56 AM
All times are GMT -7. The time now is 10:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
