Originally posted by CLrog thanks for your note, it seems like sometimes the mirror gets stuck in the 'up' position after I trip the shutter, not sure why that would happen. Often when I trip the shutter again it resets
Can you reach in and gently pry the mirror down? Sometimes, with very old cameras like the Spotmatic, the foam cushion around the focusing screen, that is there to soften the blow when the mirror flips up, can get soft and sticky. Occasionally, the mirror will stick to the foam.
If it resists coming back down, then there is probably something broken or out of adjustment inside the camera. Having this fixed, if you can't do it yourself, may be more expensive than the camera is worth.
