Originally posted by clackers A very good camera, Deb, but no camera is waterproof, which is why pros buy housings for them.
It's great at being weather resistant, as you've read, but that's not the same thing. You will not be able to claim warranty if sand or water's found inside it by repairers.
Assuming we are talking about damage only through "weather" then thats actually wrong.
I claimed warranty for a K-5II where that happened.
It seems it was a problem with the sealing of the mounted lens.
If you only use WeatherResistant gear, it "ipso facto" has to be weather sealed.
Especially if you have a "legal costs insurance" and your gear is still under warranty, you should insist.
At least that is what I did, when that first happened to me. Afterwards i took an insurance.. because you sometimes even when you know you'll get it, you can have a hard time claiming your guarantee.
(depends on whom youre talking to)
But i am pretty sure there is a way to check if you literally drowned your gear.. (such indicators where also built into some early PDAs)
That is something you can not claim warranty for - dumbness.
Cause there is a straight line between UNDERWATER |and| WEATHER RESISTANCY.
Nonetheless if you are really into professional photography and plan to use your gear under dangerous environmental conditions all (or most of) the time, you should get a "photographer insurance"...
BTW i always put an additional rubber gasket on my lenses when i go outside, because insurance or not i dont want to miss it for longer than one day.
(You put that on your lens first -its gotta be a flexible one- and after you mounted the lens, you roll it down till it slips in the "mount gap")
