Originally posted by normhead through the viewfinder: Known Pentax lens designs and designers
I can't find any reference ti the 28-105 but for some reasons I have the impression it's a Saori design. I have this impression from on of the interviews published on the forum, where I believe he discussed the design of the lens.'
But given that he designed the 16-85 afterr the 18-135, we can assume he made an effort to make it a better lens than the 18-135. just as the 18-135 was designed not to be premium lens, but better than the kit. If he did design the 28-105 then we can assume it was meant to be the FF version and an optical improvement over the 16-85 but without digging through the old interviews for the quote I can't be sure.
What can be said for sure is that every lens he's designed has been an improvement over what came before it. I think folks in the future could be collecting his designs the same way some now collect Hirakawa designs.
A wonderful link, that, by forum member 'Douglas of Sweden'.
Yeah, a lot of attributing designs is guesswork, because unless you can find a patent with names attached, no company wants to make rock stars out of its employees. Just means you have to pay heaps to keep 'em.
I get the feeling that since the Hoya/Ricoh takeovers, Saori's about the only senior optical designer they have (and from a cost perspective, management would be happy with that), so designs come out very slowly with that bottleneck. He did the 70-200, but deals were done with Tamron to get the 15-30 and 24-70 out at about the same time in readiness for the K-1 release.
If the hunch is true, this is why we see a 50mm then eventually the 85mm then sometime after the 35mm or whatever it will be. He might have underlings of some ability or another, but the chief designer probably has to devote a lot of personal time to see each project through. At Canon or Nikon, perhaps they've got ten guys at his level, with scores of assistants!
I suspect you're right about the 28-105 (physically looks similar to the 17-70 and 18-135) and probably you can throw in the 20-40, too, he does seem to have built his reputation on quality zooms. And he has other patents in novel floating element systems, so maybe the 55-300, too, which has a tiny focusing group.
A black mark against him is that when younger he put the first generation of Pentax in-lens motors into the top of the line and big 16-50 and 50-135 star lenses of the day and they were definitely under spec.
I note that the pamphlet for the SDM in the 50mm f1.4 assures it's all new and twice (Edit: 7.5 times!) as powerful as other designs, because it has to drive very heavy elements. In any case, the forum members who've shot with the prototypes have had no complaints.
