11-22-2018, 10:34 PM   #1
Réjeanne Desrosiers
Guest
Using manual lenses with a Pentax K-50
I recently bought a DSLR Pentax k50.
I also owned a film Ricoh XP-R with 3 vintage lens: 1) Sigma 60-200 mm 1:4-5.6
2) Mc Hanibex automatic 28 mm 1:2.8
3) Rikenon Ricoh 50 mm P 1:2
I have tried to use those lenses on my new Pentax but am unable to use the aperture ring even if I did what was explained in my user book ( select enable in using aperture ring on the custom setting). The shutter speed changes according to the ISO I choose but there is no difference whatsoever when I move the aperture ring.
Will apreciate any insight.
Thanks
11-22-2018, 10:59 PM - 2 Likes   #2
QuoteOriginally posted by Réjeanne Desrosiers Quote
Thanks
Since these are K-mount lenses, the actual aperture will only change at the time of image capture. Sounds like you're doing everything correctly, so you should get well-exposed shots.
Make sure you are in M mode.
In case you missed a step, here are the instructions again:
How to use/meter Manual & M42 Lenses on all Pentax DSLRs (K-1, K-3, K-5, K-30, etc) - PentaxForums.com
11-23-2018, 08:19 PM   #3
Are you using the green button? That may be the one step you have left out.It stops the lens down to the aperture you select and sets the exposure.
aperture, camera, mm, pentax, pentax help, ricoh
using manual focus lenses d.stone Visitors' Center 6 09-22-2018 06:51 AM
Just got my first DSLR, a K-5! Any tips on using manual lenses? Ropuchy Pentax DSLR Discussion 38 08-28-2018 01:41 PM
Using manual legacy Pentax zoom KA lenses and shake reduction with K1 GaryT Pentax K-1 6 09-25-2017 11:21 AM
Using Manual SMC Pentax -M Lenses With Pentax K-50 nhlblues Pentax SLR Lens Discussion 6 12-11-2015 08:11 AM
Do you use only manual focus lenses?Do a lot of folks use only manual lenses? heralu Pentax DSLR Discussion 12 01-05-2011 04:06 PM
All times are GMT -7. The time now is 06:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
