05-20-2019, 03:23 AM   #1
Cmcderment
Guest
F number problem
I have my Pentax K30 set on automatic but annoyingly frequently the F flashes at me and I cannot work out how to stop it.
Help, please?
05-20-2019, 03:32 AM   #2
MarkJerling's Avatar
Could you be using a lens with an aperture ring, not in the 'A' position?
05-20-2019, 04:02 AM - 1 Like   #3
amateur dirt farmer / mod
pepperberry farm's Avatar
or the contacts on the camera or lens need to be cleaned?
05-20-2019, 04:14 AM   #4
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by Cmcderment Quote
Help, please?
you might want to review pgs 255 - 259 of the owner's manual
here is a link to the owner's manual
http://www.ricoh-imaging.co.jp/english/support/man-pdf/k-30.pdf
which I found in the " user " review of the camera body:
Pentax K-30 - Pentax K-mount DSLRs - Pentax Camera Reviews and Specifications
and here is a link to the " in depth " review of the K 30:
Pentax K-30 Review - Introduction | PentaxForums.com Reviews
05-20-2019, 09:33 AM   #5
Otis Memorial Pentaxian
The "F--" display means that the camera has not been able to detect a lens capable of aperture control by the body. The most common causes are:
  • Vintage lens with no "A" contacts on the mount
  • Aperture ring off the "A" position
  • Grime of some sort on either the lens or body mount contacts. This may be remedied by a gentle rub with a clean microfiber cloth.
05-20-2019, 07:05 PM   #6
Riggomatic's Avatar
You can turn the LCD off.
05-24-2019, 12:49 AM   #7
cprobertson1's Avatar
It may also be worth noting that the F-value blinks if you have it in a semi-automatic shooting mode (particularly shutter priority and sensitivity priority modes) and it can't reduce (or increase) the aperture value any further.
For instance, if you set your camera up as follows:
  • Shutterspeed priority mode
  • Fast shutterspeed (e.g., 1/4000s)
  • ISO locked at a low value (e.g., ISO100)
  • Low light environment (e.g., indoors)
Then the camera will attempt to lower the F/number (i.e., open the aperture), but can only open it so far (because lenses aren't magic, though a few do come surprisingly close!).
When it's unable to open (or close) the aperture any further, the indicator flashes to indicate that it's reached its limits - depending which auto or semi-auto mode you're using that might be it.
Do be aware though, that in this situation, it will flash an F/number at you, rather than displaying "F--" - which is the result of what @Stevebrot described above!
camera, pentax help
Pentax H1a serial number problem. r.reeder Pentax Film SLR Discussion 9 04-16-2019 07:08 AM
Question Pentax Serial Number Database - Takumars 135 mm - problem with listing henrikpedersen33 Site Suggestions and Help 1 07-01-2018 03:48 PM
Adding new item to serial number base Bucky_G Site Suggestions and Help 2 06-03-2017 04:24 PM
K5 Serial Number (problem) Data Base interested_observer Site Suggestions and Help 1 12-18-2010 07:33 PM
K-5 battery problem? camera problem? user problem? imtheguy Pentax K-5 39 11-03-2010 06:02 PM
All times are GMT -7. The time now is 06:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
