06-09-2019, 04:46 PM   #1
Anthony Pezzica
Guest
manual lens compatibility
will older model manual lenses fit onto and function on digital slr Pentax cameras ?
06-09-2019, 04:49 PM   #2
amateur dirt farmer
pepperberry farm's Avatar
QuoteOriginally posted by Anthony Pezzica Quote
if it's a k-mount, usually so...
if you could tell us what lens you are talking about, we should be able to narrow the 'yes or no' quite a bit....
06-09-2019, 05:42 PM - 1 Like   #3
Kozlok's Avatar
The answer is YES much more than NO. There are a few K-Mount lenses with what's known as a Ricoh Pin that get stuck;you'll want to avoid those.
Any Pentax brand lens will fit. M42 lenses need an M42-K adapter, but work well otherwise.
06-09-2019, 05:46 PM - 2 Likes   #4
Wheatfield's Avatar
QuoteOriginally posted by Kozlok Quote
Beware the Ricoh pin.
06-09-2019, 06:50 PM   #5
Almost always, yes, in the case of Pentax-branded lenses. You can check compatibility here to see how to use each lens:
Check Lens Compatibility with Your Pentax Camera
06-10-2019, 02:26 PM   #6
Wheatfield's Avatar
Something to be aware of with M42 lenses. They are not all created equally. Some are much more equal than others. I had a customer a few decades ago that got a Mamiya screw mount lens stuck on his Pentax k mount body because of a stop down pin on the lens interfering with the release mechanism.
It wasn’t good.
camera, lenses, pentax help
Lens compatibility and Aperture on a manual MX with a manual Sicor XL MC jkcerezo Pentax SLR Lens Discussion 7 12-03-2018 07:53 PM
Manual lens - is auto ISO possible with manual shutter speed ? madbrain Pentax K-1 10 05-08-2018 07:16 AM
Is it worth upgrading from a 200mm f/4 manual lens to a 150mm f/3.5 manual lens dudemanbro Pentax Medium Format 12 02-21-2018 02:21 PM
Sigma lens compatibility and zoom lens quality/value Tripbrad Troubleshooting and Beginner Help 4 04-22-2012 08:20 PM
Manual lenses with Pentax dSLR - compatibility options? stingOM Pentax SLR Lens Discussion 22 09-05-2007 01:37 PM
All times are GMT -7. The time now is 10:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
