07-04-2019, 08:39 AM   #1
Juan Isaac S,
Guest
K-M
Tengo una PENTAX K-M que de buenas a primeras ha dejado de funciona. No se enciende. Podréis darme vuestro parecer al respecto.
I have a PENTAX K-M that has stopped working right away. It does not turn on. Can you can give me your opinion about it?
07-04-2019, 10:43 AM   #2
pres589's Avatar
It would be interesting to see what it does with a power supply for a power source instead of a battery.
Have you left it overnight with the battery out as a sort of reset? I'm just guessing here.
07-04-2019, 11:52 AM - 1 Like   #3
ismaelg's Avatar
Hola!
Si no me equivoco la Km usa baterias AA correcto? Verifica que los contactos de baterias esten limpios. Aun cuando parezcan estarlo, es bueno limpiarlos con algo levemente abrasivo como una goma de lapiz. Usualmente estos contactos crean corrosion que no se ve pero evitan buen contacto. El segundo punto es asegurarque los contactos ejercen buena presion. Con mucho cuidado levantarlos un poco.
Gracias!
Ismael
English summary: Clean the battery contacts and make sure they are properly pushing against the batteries.
Too lazy for a full translation...
Thanks,
camera, k-m, pentax help
Pentax K-M Mike Newby Welcomes and Introductions 9 06-29-2016 12:41 AM
Problème sélecteur mode de prise de vue K-m Bibinou Troubleshooting and Beginner Help 2 08-10-2011 04:59 AM
k-m and limited lenses Davidex Pentax SLR Lens Discussion 5 01-01-2009 12:17 PM
official Pentax K-m it is here ! Now ! Pedro Ernesto Guerra Azevedo Pentax News and Rumors 30 09-22-2008 07:05 PM
The new Pentax K-m entry model - picture and information leaked Ole Pentax News and Rumors 45 09-22-2008 04:07 AM
All times are GMT -7. The time now is 09:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
