Originally posted by Upsweep Hi, could I use an AF200s Flash unit on a K-70 in manual mode?
The short answer is yes. The flash provides on-flash exposure automation at two different f-number settings and may also be used as a fully manual flash. It also features a few flash dedication features that might be supported on your camera. On bodies of the time, those would include:
- Flash ready indication in the viewfinder
- Automatic setting of shutter to the X-sync speed when using either of the two "auto" modes and flash signals "ready"
Behavior on a Pentax dSLR is generally similar, depending on camera mode. For example:
- Flash ready should display in the viewfinder
- It is likely that X-sync will automatically be set to 1/180s (or last set whichever is lower) in M mode when using either of the two "auto" modes of the flash
- It is possible that X-sync will automatically be set to 1/180s or lower in Av mode depending on ambient light when using either of the two "auto" modes on the flash
There is also the outside chance that the appropriate aperture for either of the two auto modes may be auto selected in some camera modes. This is highly unlikely. Edit: Will not happen due to lack of "mode" contact on the foot.
Exposure compensation may also work. It may prove fruitful to explore the full range of camera and flash mode combinations including green button with the understanding that both "auto" modes require the proper aperture setting for the camera ISO. (The ASA/ISO setting on the flash works the slide calculator on the back and does not change the flash output.)
The flash manual may be downloaded for free from:
Pentax Manuals | Accessories (PDF password is "Pentax")
Note: I made a significant edit to clarify and and correct the earlier post. Sorry
