09-24-2019, 10:12 PM   #1
David Rutledge
Guest
Rikenon 35-70mm Macro 1:3.4-4.5
First time trying out this lens. It show F-- in the display and I can't take a picture. I have tried changing the lens from "P" to and f-stop, but no effect. Lens is in beautiful shape so I think it's probably me. Sorry for the dumb questions.
09-24-2019, 10:14 PM   #2
With the lens set to "P", the F-- should go away in the viewfinder. If it doesn't, then there might be something wrong with the lens...but you should still be able to use it after following this procedure:
How to use/meter Manual & M42 Lenses on all Pentax DSLRs (K-1, K-3, K-5, K-30, etc) - PentaxForums.com
09-25-2019, 01:39 AM   #3
I don't know this lens, but a
traditional Ricoh lens switch a resistor on a dedicated pin and is not kompatibel with Pentax. In this case it is a full manual lens for the camera and you have to change a switch in the menue to allow the camera to work with this old lens
olaf
09-25-2019, 11:40 AM   #4
jimr-pdx's Avatar
Rikenon-P is not a Pentax-A equivalent. I learned that after buying several, they only shoot wide open in auto modes. They also have the pin that can get stuck in the AF screw slot. Many have great optics, I miss my P 28/2.8 lens. I still have the XR 70-150mm but XR lenses have no pin as far as i know.
10-30-2019, 05:44 PM   #5
Check those electrical contacts with a dry cotton bud.
10-31-2019, 07:05 AM   #6
Perhaps you can post some pictures?
03-10-2020, 06:49 PM   #7
johnha's Avatar
As mentioned, Ricoh K mount lenses are not compatible with the KA electronic contacts. Confusion may arise as many independent lenses have contacts for both Ricoh P and KA mounts (usually marked as PK/R or similar). They can still be used as K mount lenses.
Anything with the Ricoh pin may get stuck in the Pentax AF coupler. The best way to remove it is suggested here: theatre of noise: Ricoh Lenses On Pentax Cameras -- The Ricoh Pin Fix
camera, lens, pentax help, rikenon 35-70mm macro
Nature Pentax K-5 Mounted with Ricoh Rikenon XR 35-70MM 3.5 (Nuthatch in Flight) Lmcfarrin Post Your Photos! 2 08-16-2018 05:08 AM
For Sale - Sold: *FREE* XR Rikenon 35-70mm f/3.5 lens *FREE* ChrisPlatt Sold Items 2 06-11-2017 04:32 AM
For Sale - Sold: Ricoh Rikenon 35-70mm f/3.4-4.5 lens 6BQ5 Sold Items 6 09-09-2014 08:42 PM
Lens contructions of Rikenon P Zoom 35-70mm f/3.4-4.5 icy Troubleshooting and Beginner Help 3 09-27-2012 11:25 PM
For Sale - Sold: Ricoh XR-1 and Uncommon XR Rikenon lens: 35-70mm f/3.5 manual zoom Nick Siebers Sold Items 7 12-14-2011 01:13 PM
All times are GMT -7. The time now is 08:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
