Originally posted by MalcS
Had the same problem with my ist*D with a new set of lithium AAs. The fix was to put the AAs in a flash, charge it up, fire once, and then put the batteries back in the camera, after which it worked fine from then on. Not sure if this is a fault with the camera or what exactly, but it seems it doesn’t draw enough power to ‘wake up’ the new lithiums initially. If you don’t have a flash, any device that draws a bit of power should do the trick (assuming the problem you are having is the same). Wierd...
Originally posted by Erictator
Had same problem with mine... I decided to just let it sit overnight with the batteries in it (off position) and it fired up the next day and has been fine since.
could be the wake up the battery thing, could be caps in the camera got lazy.
Originally posted by y0chang
The IST Dl is very finicky towards batteries. It would only accept fully charged batteries. Any Alkaline AA battery that was sitting around which lost its charge wouldn't turn on the camera. Try using a fresh charged rechargeable or the non-rechargeable Lithium (not Lithium-Ion rechargeable) and it should power on. BTW this question is how I ended up in PentaxForums and the rest is history.
Emphasis added so that I can say "
same here" to that bit.
I kind of gave up on mine but am now curious to try some of these other suggestions.
Hope the OP sees some good luck!
