02-12-2020, 01:45 PM   #1
Brian Baxter
Guest
How much is a new SD card slot for my pentax k5
How much would it cost me to purchase a new k5 Slot to be installed in my K% Pentax Camera. How do I order it.
02-12-2020, 02:08 PM   #2
bertwert's Avatar
Unfortunately, you can't order parts yourself, so to repair it, you would need to send it to a repair facility. This will be quite expensive, so it may actually make more financial sense to buy another (used) K-5.
02-12-2020, 02:16 PM   #3
I saw the following part listed on Amazon in case you are interested. I have also seen videos listed that deal with the SD slot repair/replacement.
Below is part listing I am referring to.
amazon.com : PhotoTrust Camera SD Memory Card Reader Slot Holder Replacement Metal Compatible with Pentax KX KR K5 K5IIs K3 K30 K7 Cameras : Camera & Photo?tag=pentaxforums-20&
---------- Post added 02-12-20 at 05:05 PM ----------
Most likely it would be quite a task to repair it yourself, unless you are familiar with camera repair, so the options of either getting another K-5 or having yours repaired by a professional may be how it could possibly be dealt with.
03-07-2020, 08:19 AM   #4
Wheatfield's Avatar
QuoteOriginally posted by Brian Baxter Quote
I expect that if your camera needs that sort of work, it is beyond economical repair. The K5 was beset by so many problems out of the gate, many unrepairable, that I wouldn't be putting any money into one. The K5II or K3 are both excellent cameras that should be quite reasonably priced on the used market.
camera, k5, pentax, pentax help, sd, sd card slot, slot
On K1, the card slot 1 is grayed out when choosing how to write to each slot. Why? duogl Pentax Camera and Field Accessories 5 03-29-2019 04:25 AM
SD Card Slot 1 Locked on K-1 Bartholowj Pentax K-1 2 03-28-2019 07:03 PM
K3 II SD Card Slot Cover Repair? As82 Troubleshooting and Beginner Help 19 10-04-2018 11:00 AM
Crap! My new class 10 sd card run much slower than my old class 4 sd card... liukaitc Pentax Camera and Field Accessories 15 05-31-2011 01:39 PM
SD card slot on the K5 jpzk Pentax K-5 36 11-24-2010 08:11 PM
All times are GMT -7. The time now is 11:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
