08-04-2020, 05:30 PM   #1
Wayne Bonn
Guest
F* 300mm F4.5
Camera k-5 doesn't see the focal length. With lens mounted the LED display flashes and the focal length display shows (F---). Also doesn't work in green mode. Everything else seems normal . Pic quality is great. Any ideas?
08-04-2020, 06:26 PM   #2
ismaelg's Avatar
Hello,
Make sure the contacts on the lens as well as on the camera are clean. You can carefully clean them with a pencil eraser. Also make sure the lens is properly mounted and it clicks all the way in.
Thanks,
08-04-2020, 06:28 PM   #3
jatrax's Avatar
If the camera is showing (F__) it does not see the lens.
Carefully clean the contacts on the lens and on the camera mount. A soft microfiber cloth usually works just fine. A little alcohol on the cloth can help but is usually not needed, just buff them first before you resort to alcohol.
If that doesn't work carefully examine the contact buttons and see if they are all present and in good shape.
08-04-2020, 08:08 PM   #4
Make sure the aperture ring is set to A
08-05-2020, 05:53 AM   #5
Wayne Bonn
Guest
Cleaned contacts - no help. Tried lens on different camera body - same problem.
Set aperature ring to A - success!!
Thanks for the help.
WFB
camera, display, f* 300mm, length, pentax help
Pentax-DA 55-300mm F4.5-6.3 ED PLM WR RE vs Sigma 70-300mm F4-5.6 Apo DG tsode Pentax SLR Lens Discussion 12 06-28-2020 03:55 PM
Pentax DA* 300mm f4 or Sigma 100-300mm EX DG f4 basrietkerk Pentax SLR Lens Discussion 43 06-08-2020 03:17 PM
For Sale - Sold: Pentax 6x7 300mm F4.0, 6x7 200mm F4.0, 645-A 200mm F4.0 MightyMike Sold Items 58 12-27-2019 12:30 PM
FA* 300mm f4.5 vs. DA*300mm f4 - which is better full-frame? Socrateeze Pentax SLR Lens Discussion 13 04-03-2019 05:00 PM
DA* 300mm F4 vs Pentax-F* 300mm F4.5 autofocus brewmaster15 Pentax SLR Lens Discussion 20 02-15-2018 08:36 PM
All times are GMT -7. The time now is 11:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
