08-15-2020, 08:56 PM   #1
snobrewer
Guest
K-70 LCD stops working
I have a new K-70 and after 2 weeks the LCD/monitor will not work. As well as this the auto focus on the shutter release button is not working. It is under warranty, but any simple solution would be greatly appreciated.
08-15-2020, 09:06 PM   #2
ramseybuckeye's Avatar
QuoteOriginally posted by snobrewer Quote
I would return that ASAP and have them send you a new one. That's not normal or acceptable.
08-15-2020, 09:19 PM   #3
SpecialK's Avatar
I would first check that the screen review is not disabled via the menu, and that focus is set to the shutter button and not back button. *
* I am only assuming the camera has those capabilities - I never owned that body.
08-15-2020, 10:35 PM   #4
snobrewer
Guest
Thank you for your reply. I have contacted my warranty people in Melbourne, Australia and await their reply. I have been using Pentax cameras since the 1970s and this is the first real problem I have ever had. My K-x is almost worn out and only now works in Tv shutter priority which I can still use to shoot Rugby Union football which I do a lot of most week-ends.
08-15-2020, 10:39 PM   #5
snobrewer
Guest
Thanks Special K, but as the LCD will not work for Menu, I am unable to check any settings.
08-16-2020, 03:26 PM - 1 Like   #6
You may have accidentally turned off the LCD screen. Press the Info button twice and a menu should come up allowing you to select the leftmost option with the 4-way controller arrow keys. Then hit the Info button again to lock it in. If you do not get a pop up screen with the Info button, then something is wrong with the camera.
camera, k-70, k-70 lcd, pentax help
Super Program LCD light not working ToothyWeasel Troubleshooting and Beginner Help 5 12-14-2019 01:29 PM
Help needed:Tokina atx pro 28-70 f2.8 stops autofocus vanchaz2002 Pentax SLR Lens Discussion 2 07-26-2019 01:25 AM
K100D Top LCD panel stopped working murphysf Repairs and Warranty Service 3 07-01-2019 10:48 PM
Sigma 17-70 f2.8-4.5 (FL and f-stops) fLyIr Pentax SLR Lens Discussion 6 03-09-2011 09:42 AM
rear e-dial on K20D stops working WMBP Pentax DSLR Discussion 12 04-13-2010 12:32 PM
All times are GMT -7. The time now is 05:20 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
