Originally posted by michellefilmnewbie I'm new to film camera and got myself this point and shoot cam off depop. The E code appears midroll (sometimes after 10 to 20 shots) and refuses to advance my film. 'E" or '0' bounces back and forth on my monitor. It's devastating as I have to rewind the film back to its canister and waste the rest of the unused film or try fishing out the film leader. I found that it often happens after a bumpy trip (in a car ride, or when I'm running with the camera in my hand or my backpack). It is also quite sensitive and a slight bump or shake will cause the camera to wind erratically (am only aware of it happening when the camera is empty). I got the first roll of film developed and it came out fine, but the appearance of this E code is driving me nuts. I have no clue what's happening. Is there anything I can do/ should do to prevent this from happening in the future? Any ideas why this may be happening? Could it be the way I'm loading the film incorrectly or should I get my camera checked? Thank you so much!
Welcome to the forum!
It sounds like a film loading issue and the canister is not seeded properly. That may explain when the camera is shaken/bumped the film loading "E" error happens.
Here is a link to the manual if you don't have one. Check to see if you are inserting the canister properly and there are no broken parts visible.
U Sa Ble Lilm - Pentax ESPIO 928 QUARTZ DATE Operating Manual [Page 8] | ManualsLib
Phil.
