Originally posted by Art Vandelay II That said, noise is the only aspect of IQ where I would compare them. Dynamic range, pixel sharpness, and DOF control are all in favor of the K10D. But then again, a K10D is a big freakin camera; that's why I sold it and the D200 after I got an E-P1. I simply stopped using them because they were such a pain to carry around. For some users I'm sure the Q will do what the E-P1 did for me.
I still have my K10D and I disagree with you. At ISO100, the K10D has fantastic image quality - anything above ISO100 the Q wins.
And I still think you are confusing DOF with bokeh - from what I can see of the sample images, the bokeh on the lens is quite good (better than the FA43). The DOF equivalency of the lens is pretty high - from the images I think it's roughly equivalent to f8 on the FA43, maybe a little less but not much less. Definitely not the f11 some were claiming
f8 is very usable - I shoot a lot of pictures at f8 on my FA43.
The K10D still wins by having both front and rear dials (the Q is like the lower end cameras by only having rear dial).
However, in other respects, the Q wins over the K10D. It's small enough for me to mount on my bicycle or carry in a handbag.
And I'm guessing (from the sample pictures) the AF on the Q is a LOT better than the K10D (but that's not hard to achieve!). Also wins in continuous fps.
