Originally posted by barondla On DSLR I shoot AV about 80% of the time and manual the rest. Does that even make sense on the Q? Lens is 1.9 wide open to what F8? That only gives a 4 aperture range to select. Somehow the ND filter also comes into play. Maybe Pentax is afraid, with so few apertures, it would be easy to run out of adjustment room. So they activated auto ISO. I hope not. My Minox B film spy camera always shoots at F3.5 ( there is no aperture to adjust). I will make do with it either way.
thanks
barondla ( wish it would arrive)
So far I only shot w/ F1.9 to F2.8, never stopped down further than that. I feel the DOF is great enough at F2.8, and it's pretty deep even wide open. As I said above, you can set ISO to either auto (with an upper range set by user) or specific one. Just press ISO button on the fourway button and select. Switch of AF point and four-way button functions are the same as the one on K5: press and hold to toggle. AF seems to be faster than K5 in LiveView mode, or even faster than my GF1.
I played the camera for a whole day, took nearly 200 shots. It's definitely a very fun camera to play with. It is very portable, and feels great in hand. The only thing I don't like (other than high ISO performance, which is as expected anyway for such a small sensor) is the DOF control, even at F1.9, the DOF isn't enough to isolate the focused subject and the background, unless either the subject in focus is very close or the background is far. But the photos are very sharp even at F1.9, I feel no need to stop it down even shoot at a target 10m away.
Looking at the photos, it's definitely different from those out of all the p&s cameras I ever used, but definitely can't compare w/ m4/3 or APSC dSLR that's for sure. It's a fun party and walk around camera which I'm sure most people would enjoy using, but don't expect too much out of it, especially if you wanna compare with m4/3 or APSC cameras.
