Originally posted by Laurentiu Cristofor Some nice shots and I particularly liked Devorama's, but I have to say - I have not yet seen anything that makes me feel that the Q is conclusively more competent than other P&Ss at lower ISO. I was excited by the idea of this camera design based on the assumption that the sensor will provide a step up from the current generation of compact sensors. But I don't see that advantage in any of the sample shots. It might be apparent only at higher sensitivities, but the lower ISO shots look like what other P&S cameras can produce already.
Here are a couple of shots from my current P&S - the second is a crop from the first, to show the detail that the camera can capture. You can click on them for larger sizes - I embedded small versions to distinguish them from the Q samples:
Original frame:
Crop:
The camera is the Lumix TS3 and I have more output from it
here. It is waterproof, so it manages to achieve this quality while shooting through the protective glass, which I find to be a pretty impressive feat. The drawback is that that glass causes flare when there are strong sources of light in the frame. Can't have it all.
But, with the Q using a prime lens and having a newer generation sensor, I just expected it to smoke any other P&S in terms of IQ. I just don't see evidence of that. I downloaded the PF sample image from the Q preview the other day, and it looked very average.
Anyway, these are my observations based on the few full-sized samples I managed to see so far. I still like the concept of the Q - I always wanted a full fledged compact system, but I'll wait to see what future models will be like.
Hi, it's funny you mention the Panasonic Lumix TS3 as I also own that camera and did a video review on YouTube of it a few months ago when it was released. That is my current P&S and I love the camera and the quality of images it creates in
good lighting. I think that is the key word here, good light. Most P&S fail at higher ISO or low light situations. Any decent camera can take very sharp and clear photos when provided with enough ample light. I still use my Canon SD200 (3.2 megapixel with a max ISO of 400) to take photos every now and then and it does a better job in low light then my then newer Canon SD780IS.
I own the TS3 and K-x and was already doing some RAW comparison shots between the K-x and the Q. I was going to save the TS3 for last but I'll take some more comparison shots between all three at different ISO's to compare. So far, the Q is close in IQ to the K-x at lowest ISO settings. The K-x has a bit more detail but when viewed at normal resolutions and not 100%, there are not noticeable.
Now on comparing the TS3 to the Q, even though I love the TS3 it's not the same thing as the Q. They both have the same sensor size and are relatively the same physical size as well, but that's about where the comparison ends.
Things I can't do with my TS3:
- Have a full size hot-shoe to use with standard flashes
- Change the lenses to suit a particular aperture or focal length
- Attach different types of lenses such a C, D, and soon K mount lenses
- Have full manual control both in still and video modes
- Have very good low-light performance in comparison ( the TS3 starts to need PP at ISO800 and ISO 1600 is useless on that camera for me)
Obviously the TS3 is waterproof, droproof,has GPS, etc... It's a different kind of camera. The Q is a REAL DSLR shrunk down in that it gives you all the capabilities of a DLSR in a small package with very good IQ. That's the key, the capabilities of the camera. Having the interchangeable lenses makes it more valuable then say a S95 because it gives me options like a DSLR. I can attach it to my telescope for astrophotography, or use a real flash attached to the camera. I can take the Q to a wedding and shoot photos just as easily as with my K-x and get great photos, but cut my weight and size down significantly.
If we look at it this way, we can say the Q is a new line of compact DSLR's. Eventually the IQ of these cameras will get to the point that they are as good as high-end DSLR's of today and already it's approaching or meeting K-x in quality now.
