09-13-2011, 08:57 PM   #1
devorama's Avatar
Pentax Q shoots the ISO flower
With all the talk of sensor performance, I though people might want to see some controlled comparison shots. You may remember this flower from my K-m vs. K-x or the K-x vs. K-r series. Well it's back now for the Pentax Q vs. Olympus XZ-1.
Flickr series
The earlier shots are just out of camera JPG files.
Later shots are RAW files from the Q and XZ-1 converted with no noise reduction in Raw Therapee. I tried to shoot both at the same focal length, but the XZ-1 has a power zoom with biggish steps. I used a white board to set the color balance manually, but the Q came out definitely cooler. Focus was spot focus for both on the center and both used a 2 second timer.
Also included are the ISO elevators for ease of pixel peeping.
From my estimation, the XZ-1 has better resolution. It looks like the RAW files were sharpened. But I checked and even reprocessed the files and they are that sharp with sharpening turned off. It seems like the grain of the nose is actually finer on the XZ-1, which I didn't expect because it's a lower resolution sensor.
09-13-2011, 09:38 PM   #2
mysticcowboy's Avatar
Thanks for posting these. I beginning to rethink my initial reservations about that camera.
09-13-2011, 11:59 PM   #3
Yikes, really poor showing from the Q
09-14-2011, 05:39 AM   #4
Does Raw Therapee do the Q raw files as well as it should? Pentax has says Photoshop doesn't do DNG correctly untill there is an update. What happens if you use Silkypix that is included with Q?
thanks
barondla
just got my Q and love it. The Pana LX 2 and Olympus EPL1 will be sitting a lot more.
09-14-2011, 07:11 AM   #5
If the comparison images is the ability of the Q, then it should go straight into the dustbin.
Is RAWTherapee handling the Q RAW properly?
Maybe just a jpeg comparison will be better?
Both cameras and do all the dirty tricks to churn out the JPEG but at least it will let me know what I can get straight out of camera for JPG.
09-14-2011, 07:40 AM   #6
devorama's Avatar
QuoteOriginally posted by pinholecam Quote
I'm not sure if the choice of RAW converter makes that much difference if I'm not applying any noise reduction, sharpening, exposure curves, etc. It does appear that the RAW Therapee converter does not do any barrel distotion correction by default, as I can see the distortion in the RAW files.
Just so you can see the difference, I uploaded the original JPEG files of the flower too with the Q and XZ-1. I shot them as RAW+JPEG, so the conditions are the same.
09-14-2011, 08:20 AM   #7
Edgar_in_Indy's Avatar
I just looked at the entire out-of-camera JPG series from the Q, and was actually impressed. Thanks for taking the time to post these! In the past, the output from a lot of these 1/2.3" cameras look like impressionist paintings when viewed at 100%, even at low ISO levels. But the Q looks amazing at base ISO, and holds up acceptably well when going up the ISO scale.
I was among the skeptics and the disgruntled when Pentax announced the Q, but I could actually see myself owning one of these things one day, assuming the price comes down. I think it would also make a great starter camera for my kids.
09-14-2011, 11:36 AM   #8
Hi devorama,
Are the jpegs at default image settings and High ISO NR on "Auto"?
Scott
09-14-2011, 11:41 AM   #9
devorama's Avatar
QuoteOriginally posted by snostorm Quote
Hi devorama,
Scott
Yes, default color setting (I think it's "Bright") and default NR settings. Three star quality (the highest) for the JPEG quality. I was surprised the file size for the Q was pretty small compared to the XZ-1 files. Q JPEGs were about 2 MB while the XZ-1 was about 4MB. Maybe the JPEG compression is just more aggressive even at highest quality setting.
09-14-2011, 12:56 PM   #10
QuoteOriginally posted by devorama Quote
Hi devorama,
Thanks!
I think I can pretty well extrapolate what I'd expect to get out of the Q from these and a few other samples, and AFAIC, the Q will do just fine for my purposes, set up the way I anticipate, and PP'd to taste.
Thanks for a well executed test!
Scott
09-15-2011, 12:37 AM   #11
Roberts's Avatar
The choice of RAW converter makes very big difference, even if you just convert files by using defaults, i.e., you do not touch any of sliders. Try the same RAW file (of any camera) to convert with different converters putting all sliders to 0 or start position, and you will see the difference
09-15-2011, 01:33 AM   #12
devorama's Avatar
QuoteOriginally posted by Roberts Quote
Well, I chose RAW Therapee so I could use the exact same RAW file program on both files. I just opened the Q ISO 1600 file in SilkyPix and processed it with minimum values. It seems it does the barrel distortion correction even if I don't ask for it. But the resulting file is very similar to the Raw Therapee file. The SilkyPix pic looks less sharp than the Raw Therapee one, but I think that's because I can't disable the sharpenung, But overall the changes are minor, other than the barrel distortion correction.
09-15-2011, 05:18 AM   #13
Zygonyx's Avatar
The "problem" might be that in modifying it's RAW files, Pentax has lessened numerical "born" noise, but to an other extent too, the apparent resolution of the sensor...
09-15-2011, 07:33 AM   #14
devorama's Avatar
QuoteOriginally posted by Zygonyx Quote
Has it been stated that Pentax is modifying RAW files? Are you talking about how Pentax dslr RAW files have noise reduction for high ISO?
09-15-2011, 11:49 PM   #15
Zygonyx's Avatar
Yes, Pentax has actually modified the RAW files "in-body" since the K10D, according to DxO Lab. The advantage being a better noise control.
http://www.dxomark.com/index.php/Cameras/Camera-Sensor-Database/Pentax/K10D
See the "smoothed" values on the graphs. An explanation lies somewhere in their website, but i can't find it now.
camera, files, flower, focus, mirrorless, pentax, pentax q, pentax q10, pentax q7, q10, q7, resolution, series, vs
K-r vs. K-x ISO samples (or return of the ISO flower!) devorama Pentax K-r 31 10-29-2010 02:05 AM
Nature Flower shots. dws1117 Post Your Photos! 2 08-03-2010 12:34 AM
Nature Two flower shots the swede Post Your Photos! 3 08-02-2010 04:59 PM
Macro First flower shots miss_alexx Post Your Photos! 14 04-30-2010 03:42 PM
Pentax K10 Tamron 18-250mm Flower shots eagle2 Post Your Photos! 4 05-19-2008 11:37 AM
All times are GMT -7. The time now is 02:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
