10-03-2011, 02:12 AM   #1
pentax q op telescoop
kan ik een pentax q koppelen aan een telescoop?
wat is hier voor nodig?
dank voor de antwoorden
10-03-2011, 03:27 PM   #2
Banned
I can pentax q linked to a telescope?
what's needed?
thanks for the answer
The K mount adapters should be out soon so just use that with a 2" UltraWide Prime Focus Telescope Adapter
for Pentax SLR/DSLR Cameras.
DIGITAL CAMERA ADAPTERS FOR TELESCOPES - Largest Selection!
Here is my K-7 with the 2" adapter :
10-03-2011, 03:52 PM   #3
Stone G.'s Avatar
QuoteOriginally posted by jogiba Quote
Or, if your scope does not have a 2" focuser, you might use a common T2 adapter in conjunction with the K-to-Q mount adapter mentioned.
PS: Some interesting first photos with a 750mm f/5.6 scope to be found here:
http://www.tomytec.co.jp/borg/world/blog/2011/09/20110917.html
10-04-2011, 05:32 AM   #4
ebk
[langtitle=nl]pentax q[/langtitle]
The K mount doesn.t fit the penrax q
10-04-2011, 06:41 AM   #5
Banned
QuoteOriginally posted by ebk Quote
Attach the K- mount telescope adapter to the Pentax Q K-mount adapter.
Pentax Q with K mount lenses using the Q-K mount adapter.
If your scope accepts 2" eyepieces consider our True-2 adapter, if your scope accepts 1.25" eyepieces this is the way to go. The included parts will allow you to couple your SLR or DSLR camera to a standard 1.25" eyepiece port for "prime focus" astrophotography.
http://www.cncsupplyinc.com/slrkits.htm#PFK
2" Pentax K version:
http://www.cncsupplyinc.com/true2_pentax_k.htm
10-18-2011, 11:36 AM   #6
Mistral75's Avatar
You can also use a T mount --> Q mount adapter like Kipon's (around 60 USD on eBay)
10-19-2011, 08:59 PM   #7
Banned
The Q makes even the DA40 look like a chunky lens.
camera, mirrorless, pentax, pentax q, pentax q10, pentax q7, q10, q7, telescoop, voor
All times are GMT -7. The time now is 05:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
