Originally posted by fuent104 The second image is amazing. Macro shots like these are exactly what I thought of when the Q was announced, and it's great to see someone taking advantage of it to the fullest. How far was your lens from the spider? I'm amazing you were able to get such a steady shot of such a small creature. Did you use a tripod?
Absolutely fantastic work. It's almost like he has a facial expression.
Thanks for the comment.
The lens was probably 35-40cm away (1:1 is about 30cm for the lens)
Unfortunately the flash sync is only 1/15 with the 3rd party adapter, so I have to make do with 2 table lamps for the time being (captured the subject)
I managed by bracing and the shutter speed was pretty decent at above 1/200 with the lamps, but then at the high magnification, many shots still suffered from camera shake.
Since the concept is now proven, I'm plonking in the cash for a bright video LED light, that can be mounted on the hot shoe.
There is a lot of technique to work on, which is why I mentioned that its still very preliminary.
Trying out with tripod, LCD loupe, multi shots, etc will be the next steps to explore on making the shots better and more consistent.
Originally posted by Dr Orloff Some great examples all round. Those macro shots (along with the moon shots on the other thread) are just what I was hoping to see before splashing out on an adaptor. I would be interested in seeing the larger versions on flickr if you are planning to upload them.
If you are referring to my macros shots, then they are 1024 on my flickr.
I must say that a lot of work still needs to be done to eliminate camera shake (ie. tripod, multi-shots, etc)
