Originally posted by johnmflores First time birding with the Q7 + Pentax Q-K adapter + DA 55-300 HD WR + monopod with fluid pan head. I knew that I was taking a risk using a monopod instead of a tripod but I wanted ease of movement. I had practiced at home for nearly a week to find the optimum shooting technique and it turned out OK. Both shots at 300mm (~1400mm EQ) and one or two stops from wide open, ISO320, 1/1000s (mechanical shutter. Shake Reduction was on.
I've just received a walking-stick/monopod, which I'm hoping to use in circumstances like yours. My first experiment with an adapted lens was taking a picture of our street sign from a block away using a 70mm-210mm Canon FD lens; I took that picture with no support (it was entirely hand-held), but it was quite sharp. Obviously I'll have to do a lot of experimenting with the monopod, but I'm hoping that the in-body "shake resistance" will be up to the challenge. Of course, your using a 1/1000 shutter helped your results a lot, but I view the clarity of your pictures partly as a tribute to the in-body shake resistance (and to your technique), so I'm hopeful that my walking-stick/monopod will also work out. Thank you for the encouraging results!
