05-24-2017, 08:44 AM   #5446
rmcnelly's Avatar
Pentax Q-S1 w/MC Rokkor 58/1.4 x 4.6 crop factor = 267mm FF
--Rick
05-24-2017, 11:42 AM   #5447
rmcnelly's Avatar
Pentax Q-S1 w/MC Rokkor 50/3.5 Macro
--Rick
05-25-2017, 11:55 AM - 1 Like   #5448
rmcnelly's Avatar
Pentax Q-S1 w/Tamron SP 60-300mm. Shot on tripod at 300mm = equivalent 1380mm on full frame. No crops.
Hundreds of tiny critters in the yellow, but easier to see the ones on the white petals.
Switched to Macro on the lens and moved in to where I could focus again.
Moved in even closer for maximum magnification (1:4), and a fly showed up.
--Rick
05-25-2017, 02:46 PM   #5449
rmcnelly's Avatar
More from the Pentax Q-S1 w/Tamron SP 60-300 at 300mm = to 1380mm FF when used with this sensor. Shot in RAW and edited of course, but I remain amazed at how sharp this lens is.
At f/5.6
This was at f/6.3 and was sharper than the 5.6 version. If you open the pic on Flickr you can just make out the text on the grey pole to the right.
The same at 60mm = 276mm on FF:
Mockingbird at 300mm = to 1380mm FF:
--Rick
05-25-2017, 09:05 PM   #5450
wolfiegirl's Avatar
QuoteOriginally posted by rmcnelly Quote
At f/5.6
--Rick
wow... how are you using the 23a here? a tripod? monopod? handheld?
05-26-2017, 03:43 AM   #5451
rmcnelly's Avatar
QuoteOriginally posted by wolfiegirl Quote
Thanks!
All the Tamron SP 60-300 (23A) pics were shot using a tripod and 2 second self-timer. I will try a monopod when I'm able to.
--Rick
05-26-2017, 12:55 PM - 3 Likes   #5452
Genuine Q with Pentax-Auto 110 50/2.8
05-26-2017, 03:11 PM   #5453
wolfiegirl's Avatar
Thanks!
--Rick
2 second timer setting on the q? Or with an additional remote?
05-26-2017, 04:48 PM   #5454
rmcnelly's Avatar
2 second self timer on the Q-S1, to remove vibrations from pressing the shutter release. A remote would be nice to have.
--Rick
05-26-2017, 06:04 PM - 1 Like   #5455
Beautiful image Piotrek K! That eye is something.
rmcnelly, you really do want a wireless remote with the Q. You get almost instantaneous "mirror lock up" with a mirrorless camera. It is so great for ultra telephoto photography. No vibration.
Thanks for sharing
barondla
05-26-2017, 10:10 PM   #5456
wolfiegirl's Avatar
Interesting. I thought havng a monopod/tripod was enpugh to stop the vibrations. Guess i should ramp it up a bit eh? All my recent qs1 shots were taken handheld while mounted on the monopod
05-27-2017, 05:12 AM   #5457
rmcnelly's Avatar
At 1380mm equivalent focal length it doesn't take much to jar the image and the length of this lens just adds more risk of movement. I've used this lens on my Panasonic GX8 which has a 2x crop factor and use the self timer to reduce vibrations when taking shots of the moon. I'm struggling to get a smooth shutter release without jerking the Q-S1 and may try using a hot shoe mounted thumb rest from my X100 to see if that helps.
I took the Tamron SP 60-300 out yesterday with the monopod and found it very difficult to keep steady at the 300mm setting, much easier at 200mm = 920mm FF equivalent . I tried changing my left hand grip either on the lens or the monopod without finding a clear solution. I'm recovering from an extensive left rotator cuff surgery and currently have little strength/endurance with my left arm :-(. I think I'll have better results once my shoulder fully heals.
05-27-2017, 07:40 AM   #5458
Na Horuk's Avatar
With super telephoto vibrations are a real problem! With DSLRs even the mirror movement can cause visible vibrations. On the Q, that is not a problem. But pressing the shutter button is a big shake, so using timer (even better, with a remote) is best. Don't move around the tripod, as walking nearby can cause vibrations (this is mostly a problem for long exposures). Even wind or a breeze can cause vibrations if the lens is big.
The heavier the tripod, the less this will be a problem. But heavy tripods are bulky and difficult to transport so you have to find a compromise.
Of course, technique is important as well. For me, my results improved once I learned to press the shutter button slowly, gently. When I first started I didn't even notice that when I pushed the button I actually pushed very suddenly and with too much power. Its not needed and it has negative consequences. If you are hand holding the camera, using a good stance or bracing against something like a wall or tree can make a big difference, as well. Walking quickly, then suddenly stopping, extending arms while breathing heavily and snapping a shot usually leads to blur. Taking a couple seconds and being aware of yourself improves things a lot
Edit: Sorry if I went on bit of a rant there its just something I struggled with when I first started and its a weird realization people don't often fully appreciate
05-27-2017, 08:18 AM   #5459
rmcnelly's Avatar
Q-S1 and Tamron SP 60-300mm Adaptall lens, shot on a monopod on a breezy day. More keepers than I thought.
Severe crop, just caught the eagle at the edge of the frame.
Severely backlit, but shot in RAW so was able to pull some color out of the wing.
05-27-2017, 06:52 PM - 1 Like   #5460
rmcnelly's Avatar
Pentax Q-S1 w/Super-Takumar 35/2, using a fisheye lens profile in Lr to create the distortion for the abstract.
air force, camera, eye, flash, flickr, lens, mirrorless, palm springs, pentax, pentax q, pentax q10, pentax q7, phil, pm, post, q-s1, q10, q7, rain, shot, studio, thanks, time, triggers
People I now have to share my K7 dgaies Post Your Photos! 25 01-18-2014 04:21 AM
Macro Let's share this one! eaglem Post Your Photos! 4 08-20-2011 03:47 PM
Nature We Like To Share! eaglem Post Your Photos! 4 04-22-2011 07:21 PM
Something to share Mallee Boy General Talk 7 05-13-2010 03:50 PM
Tips for shooting lens comparison shots you like to share? cheekygeek Pentax SLR Lens Discussion 5 01-21-2010 05:55 AM
All times are GMT -7. The time now is 03:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
