11-23-2012, 01:38 AM   #871
crewl1's Avatar
LeRolls I like the results on those bottles, nice shots.
11-23-2012, 07:28 AM   #872
baro-nite's Avatar
Another bottle: (cross-posted from https://www.pentaxforums.com/forums/mini-challenges-games-photo-stories/19001...lit-shots.html)
01 Standard Prime, shot in RAW and processed in Silkypix, taking advantage of its built-in lens correction (which works well; I shot RAW+ and directly compared the Silkypix correction to the in-camera correction), plus its perspective control options.
11-23-2012, 09:37 AM   #873
LeRolls's Avatar
QuoteOriginally posted by crewl1 Quote
Thanks! Much appreciated!
11-23-2012, 06:18 PM   #874
baro-nite's Avatar
First attempt at Q astrophotography, with DA*200 on 1.4x-L converter, 2 stops down (effective f/8):
11-23-2012, 07:12 PM   #875
jpzk's Avatar
Countdown to rocket launch.
Monkey Ball Bush ready to disperse seeds.
Q + DFA100WR on Fotodiox q-k adapter, AF540 flash
Holy cow !! What a set up you've got there, Larry!
I am truly amazed how those macro shots turn out with the Q!
JP
11-23-2012, 07:32 PM   #876
stormtech's Avatar
Very nice Larry! And thanks for showing your setup - I love to see gear photos and the setup used.
One question - why the Better Beamer for a shot like this? Were you trying to concentrate the light to a small area?
11-23-2012, 08:01 PM   #877
Docrwm's Avatar
QuoteOriginally posted by stormtech Quote
I thought that unit had a soft panel in the front. I thought he used it to get a more diffuse light.
11-23-2012, 08:44 PM   #878
stormtech's Avatar
QuoteOriginally posted by Docrwm Quote
Oh - right you are! I thought it was a Better Beamer for some reason - now that you mentioned it I looked again and see it is a softbox.
Thanks for setting me straight Doc!
11-23-2012, 10:34 PM - 1 Like   #879
I've been considering "going light" by taking only the Q on my next holiday abroad, so I took it along for an evening birthday celebration. I remain impressed with the Q; I can lean on the IS and keep the ISO down if I'd like (1/15 is a sure thing, 1/8 is almost as sure):
Or I can push the shutter speed up to more easily capture live subjects... This one at ISO 3200:
I'd like to figure out how to get custom WB to render more neutral, as mine seems to take on a magenta hue fairly typically. In general, though, I really can't fault this camera. It's so darn small, and so darn good.
11-23-2012, 11:08 PM   #880
crewl1's Avatar
QuoteOriginally posted by jpzk Quote
JP
Thanks JP. The Q ia a wonderful machine for macro. WIth the Fotodiox I am still battling the 1/13 sync speed, so took a ton of shots to get just a few that worked since it was a bit breezy.
Can't wait for the built in shutter of the OEM adapter so I can use faster shutter speed. The flash and DFA100 I had bought previously for macro with the K-5, but the Q takes it to a whole 'nother level.
Hi Stan, thanks. I am always fascinated with how others set up for their photography, so I like to show my methods whenever I can. It helps me too when others see a setup and give suggestions for better/easier/cheaper ways of getting the same result.
The thing on the front is a diffuser as Doc points out. It's my 'Pringle can' way of getting light right over the subject. (Member hangman43 does wonderful insect macro this way.) https://www.pentaxforums.com/forums/photographic-technique/184991-need-help-i...ml#post1948806
I started doing it with the K-5, and it works for the Q in this setup. The diffuser is an even more generic version of this, I bought it locally. Cowboystudio Large Universal Studio Softbox Flash Diffuser | eBay
You got it Doc, I've been trying to learn from the macro forums.
11-23-2012, 11:17 PM   #881
crewl1's Avatar
Baro-nite, I like the backlit and the moon shot. Lucky for us you could still hold the Q steady after getting through that 1964
11-23-2012, 11:19 PM   #882
crewl1's Avatar
QuoteOriginally posted by ndjedinak Quote
I remain impressed with the Q; I can lean on the IS and keep the ISO down if I'd like (1/15 is a sure thing, 1/8 is almost as sure): IMGP0538_LR by ndjedinak, on Flickr
Very nice results, my high ISO shots on the Q leave a lot to be desired. The glove shot looks really good.
11-24-2012, 12:50 AM   #883
Docrwm's Avatar
Nice setup, macro is a demanding mistress.
11-24-2012, 06:22 AM   #884
baro-nite's Avatar
I had help.
11-24-2012, 06:56 AM   #885
Thanks, the key is to shoot RAW and process in a converter that allows you to fine tune noise reduction. I don't mind grain so I turn luminance NR off entirely and sprinkle color reduction to taste. Don't underexpose and pull up shadows, just leave the ambiance as-is. If you shoot "stuff" you can dial in some -EV for more ambiance. For people, shoot 0EV or you'll want to pull up shadows on skin in post, and that won't go well That's it, really, no special magic! The Q's sensor is quite good.
Here's a silly shot of a friend at 3200.
As I mentioned, my Q tends to push custom WB to the cool and magenta side. I'd like to sort that. Otherwise, impressive for a tiny sensored compact camera! To be honest, I personally couldn't do a whole lot better with film in this murderous lighting. And to think the Q fits in the palm of your hand. Astonishing! Here's a shot from years ago on Fuji 800z negative film pretty similar in nasty lighting, I think.
air force, camera, eye, flash, flickr, lens, mirrorless, palm springs, pentax, pentax q, pentax q10, pentax q7, phil, pm, post, q-s1, q10, q7, rain, shot, studio, thanks, time, triggers
People I now have to share my K7 dgaies Post Your Photos! 25 01-18-2014 04:21 AM
Macro Let's share this one! eaglem Post Your Photos! 4 08-20-2011 03:47 PM
Nature We Like To Share! eaglem Post Your Photos! 4 04-22-2011 07:21 PM
Something to share Mallee Boy General Talk 7 05-13-2010 03:50 PM
Tips for shooting lens comparison shots you like to share? cheekygeek Pentax SLR Lens Discussion 5 01-21-2010 05:55 AM
All times are GMT -7. The time now is 07:53 AM. | See also: NikonForums.com, part of our network of photo forums!
