01-30-2012, 02:23 AM   #1
i_trax's Avatar
the Q MF with external monitor
Hi Guys,
I just discovered that you can connect AV cable ( Yellow+white RCA) to the external monitor and you would get the Live View of the sensor.
same goes with K7 and KX ( just tested), making manual focusing even more easier, magnification obviously still works.
do not have micro HDMI cable so can not test that output but I think I remember someone stating that Q switches automatically to playback mode after HDMI is connected.
so, need to look for used LCD field portable monitor now........
01-30-2012, 03:55 AM   #2
Interesting. Seems like I tried this before the firmware update and it wouldn't work. If I remember correctly it wouldn't fire with cable plugged in. I was using the RCA jacks. Will check out again. Hope they have fixed it.
thanks
barondla
01-30-2012, 05:38 AM   #3
i_trax's Avatar
well, it does work with 02, I can manually focus with 4x and take a picture -no problem.
I do not have any MF lenses ( 03,04 or 05) and I do not have K/Q adaptor as yet to try MF K or M42 lenses.
my friend has a Marshall ( reminds me good old british valve guitar amp) portable field LCD monitor, will try to borrow it when I get back from Europe and get my K/Q adaptor.
kind regards
jack
cable, camera, hdmi, mirrorless, pentax q, pentax q10, pentax q7, q10, q7
Where can I buy a monitor calibration tool or get my monitor calibrated, I'm in Texas JGB Photographic Technique 10 12-22-2010 12:47 AM
Is it possible to hook up an external monitor on the k-x? phuey Video and Pentax HDSLRs 5 07-25-2010 09:43 AM
External Mic Malsi Video and Pentax HDSLRs 17 03-28-2010 07:30 PM
External vision monitor for K7? petercrane Video and Pentax HDSLRs 1 12-25-2009 10:10 AM
A common garden 17" CRT monitor vs an average 20-22" LCD monitor for image processing bc_the_path Digital Processing, Software, and Printing 6 07-11-2009 02:28 PM
All times are GMT -7. The time now is 06:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
