Originally posted by stormtech I see you have the plate slid pretty far back on the gimbal mount - did you get it to balance properly?
Not perfectly. That is a 60mm, I have a 70 and 100 on order.
Originally posted by VisualDarkness Haha, nice setup! I see why you need the sight after trying out my Sigma 150-500 with the Q.
It is a pain trying to find anything without it, more so if it is a bird in a tree. Every leaf looks like the next one
With the DA*300 I could use the scope turned off - put the target in the middle of the view and I was in the vicinity.
With the Bigma at 500 I have to use the lighted red dot otherwise the critter is gone before I can find it in the frame.
How do you like the 150-500 with the Q?
