03-21-2014, 11:51 AM   #931
crewl1's Avatar
QuoteOriginally posted by Expeditioneer Quote
Understood.
But I wounder, would you be willing to post a 100% crop comparison between the two photos above?
I still have a hard time wrapping my head around the Q7 being so superior given that the Q10 should have a lot more pixels on target.
Here are the Q first, then the Q7. The differences in magnification are apparent.
Since both are shot at f5.6 on the lens, the Q probably loses some sharpness because diffraction occurs earlier.
The wider pixel pitch on the Q7 lessens diffraction effect and allows a bit more detail to be retained.
They are both straight out of the camera, some PP could be used to improve the Q shot.
I do not usually crop my Q or Q7 shots except for framing/composition, the natural crop from the small sensor is typically more than enough.
I think paired with a good lens either camera will serve it's purpose.
Again I do not have experience with astro photography so your results may vary.
Q
Q7
03-22-2014, 04:01 PM - 1 Like   #932
Moorhen with original Q, chinese adaptor and DA*300mm. Shot at 1/100 sec, wide open and ISO 640
03-22-2014, 05:37 PM   #933
Super comparison shots crewl1! Thanks for all the work you put into this "project". Helps people see the difference.
thanks
barondla
---------- Post added 03-22-2014 at 07:43 PM ----------
Awesome Moorhen capture, Blythman. Nice detail with a knock out background. Image quality holds up great at ISO 640. Well done.
thanks
barondla
03-22-2014, 05:51 PM - 1 Like   #934
Weather has been terrible in the midwest, US this winter. Did get this image of a Turkey. Not bad considering it was shot thru a picture window at a 45 degree angle and it was warm in the house but cold out doors.
Q/Pentax DA*300/Pentax adapter and RD10 reddot sight.
thanks
barondla
PENTAX Q  Photo
03-23-2014, 05:54 AM   #935
hnikesch's Avatar
Great stuff guys, Thanks for the comparison shots Larry,
Blythman nicely done I like the shot,
barondla, I have shot a few Turkey's with my Q but not as well as you did this one. The turkeys I have seen were way to far away and I had to crop.
03-30-2014, 09:27 PM   #936
crewl1's Avatar
These are cross posts from the 300+ thread, all using DA*300 and Q7 with Pentax adaptor.
ISO 100, f5.6, shutter speeds varied.
Coot
Tired squirrel
Yellow Chevroned Parakeet
---------- Post added 03-30-14 at 09:29 PM ----------
QuoteOriginally posted by Blythman Quote
I really like the colors and framing of this , nice shot! Lets see some more
03-30-2014, 09:42 PM   #937
VisualDarkness's Avatar
QuoteOriginally posted by crewl1 Quote
Coot
Tired squirrel
They are amazing! It's quite ironic that "pro's" and proclaimed experts call K-lenses on the Q a waste of time and proclaim cropping instead, while you and others provide proof of its usefulness time after time.
I've been thinking of getting a Gimbal for my shooting with the setup. Right know I got a big Feisol Ballhead. What do you think?
03-30-2014, 09:57 PM   #938
crewl1's Avatar
Thank for the kind words VisualD!
I tried a ballhead initially but felt it was a bit hard to manage when I wanted to make small adjustments in a particular direction.
Panning was fine but tilting was a bit unwieldy since there is so much overhang and the adjustments needed are very tiny and if I loosened it too much it would just fall over.
Even the cheaper gimbals help, because if the setup is balanced properly you can keep very slight tension and can make minor adjustments and the lens stays where you put it.
You could even go part way and put a sidekick style gimbal on your ballhead.
I now use a PromediaGear Tomahawk on a smaller tripod when I don't feel like carrying the larger Katana.
03-30-2014, 10:06 PM   #939
Sounds like I need a gimbal in the future then. Thanks for the feedback!
04-17-2014, 01:49 AM - 1 Like   #940
Had some fun with the Q + Adapter + M135mm f3.5 lately. Here are the results:
Q Birding - Magpie von Diggoar auf Flickr
Q Birding - Parentship von Diggoar auf Flickr
05-18-2014, 01:44 PM - 2 Likes   #941
baro-nite's Avatar
My first Q birding session in a few months: DA* 300, moderately cropped.
05-18-2014, 03:30 PM - 1 Like   #942
Emperor and Senpai
VoiceOfReason's Avatar
I had my Sigma 150-500 with a solar filter on it at around 300mm. I need a better tripod than that one I got at Best Buy for 35 bucks.
05-18-2014, 04:19 PM   #943
QuoteOriginally posted by VoiceOfReason Quote
Attachment 222171
pretty cool, what filter are you using? I imagine it was a bit difficult to find in 86mm?
05-18-2014, 04:26 PM   #944
Emperor and Senpai
QuoteOriginally posted by jezza323 Quote
I'm using a sheet of Thousand Oaks solar filter material that I cut down to fit an 86mm UV filter. It works really well. I do plan on a hydrogen alpha filter next, but that's going to hurt. Alot.
05-26-2014, 10:09 PM - 1 Like   #945
I got a Sigma 500mm f4,5 APO (first version), Nikon mount, here on the Pentax Q with a Kiwifoto G adapter:
the subject also explains why I have issues taking pictures of birds in the garden.
Now 2 images of the set-up taken with 75mm on a APS-C sensor:
adaptor, camera, focus, frame, hummingbird, images, iso, loupe, marco, mirrorless, nikon, pentax, pentax q, pentax q10, pentax q7, q-s1, q10, q7, setup, shot, shots, sigma 500mm, sort, thanks
Post your "Park Bench" "or "Picnic Table" images tessfully Mini-Challenges, Games, and Photo Stories 1439 15 Hours Ago 10:06 AM
Don't say Pentax "Q" in French ... "Q" = "cul" = "A--" Jean Poitiers Pentax Q 52 11-10-2013 06:25 AM
"Focus Adjustment Washer" replacement...(with images) Catalana Pentax K-5 18 11-04-2012 03:40 PM
"Real Life" K5 AF.C images yet? jpzk Pentax K-5 69 02-02-2011 03:48 AM
How do I turn this so-called "film" into images? Todd Adamson Pentax Medium Format 12 01-07-2011 03:33 PM
All times are GMT -7. The time now is 01:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
