So I know others have done this before, but I couldn't find the shot. Here is a shot I took the other evening with my Q10 and the DA* 300mm (Pentax Q to K adapter). I seem to recall the picture I saw someone else took was sharper, but maybe it was the same. I certainly has learned that there is very little room for error.....
BTW, I did some extensive testing of my lenses on the Q and compared to my K3. The DA* 300 on the K-3 is better than any of my shorter lenses (77/100/M135/A135) on the Q - comparing cropped pictures at same stopped down aperture. The 100/135 lenses on the Q are about the same as my K3 + 55-300mm at 300mm. The DA* 300mm on the Q blew away K-3+DA*300mm cropped pictures. I'll try to post more of the results later if I figure out how to it present it in a reasonable way. I would be curious to see how well the K-5 perform in the same tests. Regardless it is somewhat of apples and oranges comparing size of equipment, costs, capabilities (i.e. no AF on Q), 5.6x difference in equivalent focal length, and size of resulting cropped pictures... Very intriguing!
Getting my Red Dot Monday, and an 01 early next week. Seriously thinking of upgrading to the Q7...
Pictures below 1) Moon with DA* 300 at -1 (f5.6, 1/80 sec) 2) Non-cropped 300mm Test picture (I had a heack of time getting enough distance without moving everything in my yard! ) The following all taken at the same distance and cropped to the same area - 3) K-3/DA*300 f5.6 4) Q/DA*300 f5.6 5) K-3/HD 55-300 f5.8 6) Q/DFA100WR f5.6
