Originally posted by wildman A few frames using the 560mm scope and the Q.
This should give me about 70x magnification.
All full frame at about a distance 60-70 feet. Remember these birds are barely larger than a man's thumb.
Big disadvantage of the Q for this kind of shooting is the slow buffer for RAW files. It's just too damn slow for fast moving birds forcing me to use JPG.
Then I have to give up the advantages of RAW processing which is a big deal with such a tiny sensor and using high ISO.
Superb pictures which are now missing
Same problem with the Q : too slow with raw, I use jpeg only
Q7 : jpeg + raw is ok
What is your scope model ? I still remember the picture, it seems to be much longer than mine ?
---------- Post added 04-20-15 at 04:26 PM ----------
Originally posted by barondla Beautiful images wildman, they are sharp. To lessen the Q Raw buffer problem I bracket. Set Q to Raw, set to autobracket. Set brackets for -.3, 0, +.3. Q will shoot faster than normal. No idea why.
thanks
barondla
Yes, it was a very good tip you gave earlier, bot only jpeg with the Q, raw is too slooow, and jpeg+raw with Q7
