06-27-2015, 09:49 PM   #1141
crewl1's Avatar
QuoteOriginally posted by raider Quote
Tried out the DA*300 and the Q adapter this morning...just a quick test at the backyard..
Getting a good focus is difficult and need plenty of patience and need to take many shots too.
Focus is critical. use the x8 magnify to confirm focus, I found it works better for me than peaking.
Spot 1 on the adapter works best for me on the DA*300.
One thing I would suggest is take the shot slightly underexposed, then bring it back in post.
The sensor tends to blow out highlights easily, so I shoot around -.5 EV usually.
Also 2 sec delay will help stop shake problems.
06-27-2015, 10:08 PM   #1142
raider's Avatar
QuoteOriginally posted by crewl1 Quote
Thanks for that. I also shoot at the "1" setting mark on the adapter. I will take note of the -0.5 EV exposure. I also use the infrared remote for a 3 sec delay but I think the tripod is not that steady...slight breeze will cause the setup to sway slightly....normally not a problem at all when shooting the K-3 but on the Q, any slight movement will create havoc.
06-27-2015, 10:32 PM   #1143
Exactly my experience as well. In Raw I can usually get by at -.3
01-04-2016, 02:43 PM   #1144
I think this great thread needs some bump. For extreme reach I usually use my Tamron-Adaptall 60 - 300 (23A) lens with my (genuine) Q. But another "reach" option viable for me is to have good quality extreme small and handholdable telephoto package. For it I use either Pentax-110 50 mm lens with aperture washer stopping it to f 3.2/3.5 or SMC- Pentax M 100/4 Macro wide open or at 5.6. Both photos below were made without tripod/monopod with 100 mm lens.
01-05-2016, 04:21 PM   #1145
Phenix jc's Avatar
QuoteOriginally posted by Piotrek K Quote
You're right, extreme small becomes powerfull, Pentax-110, or C-Mount, 50mm, 70/75mm.with a Q7, and even more with a Q
(I have a 152mm C-Mount but it's a loooong lens
C-Mount lens have iris, and the fact is you can stop down more than I thought, or than I have read (diffraction & small sensor problem)
But...
But, the bloody rear screen can be a pain in a bright day light, and put your nerves to the test
No viewfinder, now and never as the Q line is most probably dead...
Nice shots BTW!
01-05-2016, 06:34 PM   #1146
QuoteOriginally posted by Phenix jc Quote
But...
Nice shots BTW!
We've been around this track many times. Some don't see a need for an EVF, but those of us who use long lenses most certainly do. I have a hoodman clone that I attach to turn the LCD into an EVF when using it in this way. Focusing is still a tad iffy because of limitations on the LCD, but it is better than nothing. In most cases I've felt that my pictures are as good as the lens can deliver, but I always have a faint voice wondering if focus could be the weak link. I just recently spent real money on a genuine adapter in an effort to eliminate as many potential weak links as possible, because it has occurred to me that rolling shutter could also create slight issues that might be indistinguishable from bad focus or poor resolution from the lens. (and I keep in the back of my mind the hope that once resources demanded by the FF are released ...)
added: I recently got a Tamron 23A which was babied by its previous owner, but I haven't had an opportuity to try it out on the bird feeder in our back yard.
01-11-2016, 07:10 AM - 1 Like   #1147
johnmflores's Avatar
K3 + FA31
Building the new Tappan Zee Bridge
by John Flores, on Flickr
K5 + DA55-300 @ 55mm
K5 + DA55-300 @300mm
Q7 + DA55-300 @300mm
01-11-2016, 08:29 AM   #1148
QuoteOriginally posted by johnmflores Quote
I really like this picture! Did you use the Pentax adapter? If so, what aperture setting did you use? (I'm becoming more and more conscious of aperture as I take super-long pictures with that camera).
A new Tappan Zee Bridge! Wow!. I made a number of trips across the current/old bridge when my sister-in-law lived in Tarrytown NY (now she lives in Calif)
01-11-2016, 10:39 AM - 1 Like   #1149
baro-nite's Avatar
Nice work by johnmflores documenting an impressive project, while showing off the reach of the Q.
Did my first Q work in a while yesterday, with the DA* 300:
01-11-2016, 12:23 PM   #1150
QuoteOriginally posted by baro-nite Quote
Nice pictures from you also.
If so, what aperture did you use??
01-11-2016, 12:34 PM   #1151
QuoteOriginally posted by reh321 Quote
Thanks. Not sure, but the 55-300 is F5.6 @300mm, so I probably shot it wide open or 1 stop (or 2 stops at the most) closed to try and control diffraction. And then I did some sharpening, clarity, and dehazing in Lightroom. Not too much, but not a little.
01-11-2016, 03:47 PM   #1152
baro-nite's Avatar
In my case, Pentax adapter with the aperture set to +1. I pretty much always use it this way with this lens, except when accidentally changing the setting.
03-11-2016, 11:34 AM   #1153
Mothballs's Avatar
For those that mess with settings: in both raw and jpg settings, do you mess with your contrast and sharpness sliders at all? Does it have much effect with the raw?
03-11-2016, 05:13 PM - 3 Likes   #1154
Jupiter with Galilean moons at 5600mm
Here's a couple from the recent Jupiter and full moon alignment last month. You can click through the pics for more.
Pentax K20d with Tamron ADII 500mm mirror (750mm):
The bright full moon with Jupiter and four of itís largest moons, winter 2016.
Pentax Q with SMC 1000mm (5600mm):
Closeup of Jupiter and itís Galilean moons: Io, Europa, Ganymede, and Callisto.
More of 'Camping with the Stars' at:
https://kayakfari.wordpress.com/kayakfari-art/art-of-darkness-camping-with-the-stars-part-i/
03-14-2016, 05:52 AM - 1 Like   #1155
very cool shot of Jupiter and it's moons
the wood ducks are back in my pond so got chance to get some with the Q, Q-k adapter always use setting 1 or less (I have found going higher does not improve the picture quality). Sigma 500mm 4.5. i either use a remote or the 2 second delay to minimize my movement
the female was cropped because the male decided to move his head and screw my picture up
adaptor, camera, focus, frame, hummingbird, images, iso, loupe, marco, mirrorless, nikon, pentax, pentax q, pentax q10, pentax q7, q-s1, q10, q7, setup, shot, shots, sigma 500mm, sort, thanks
Post your "Park Bench" "or "Picnic Table" images tessfully Mini-Challenges, Games, and Photo Stories 1438 1 Hour Ago 02:13 PM
Don't say Pentax "Q" in French ... "Q" = "cul" = "A--" Jean Poitiers Pentax Q 52 11-10-2013 06:25 AM
"Focus Adjustment Washer" replacement...(with images) Catalana Pentax K-5 18 11-04-2012 03:40 PM
"Real Life" K5 AF.C images yet? jpzk Pentax K-5 69 02-02-2011 03:48 AM
How do I turn this so-called "film" into images? Todd Adamson Pentax Medium Format 12 01-07-2011 03:33 PM
All times are GMT -7. The time now is 03:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
