Show Printable Version 179 Likes Search this Thread
03-26-2016, 08:51 AM - 1 Like   #1171
QuoteOriginally posted by reh321 Quote
I'm wondering whether using a built-in aperture ring gives sharper pictures than using the "aperture control" on the Pentax adapter does. My reason for asking is that when I did do some backyard testing at 300mm, my Sigma 70-300mm APO lens {using its aperture ring} gave sharper results than my Pentax-DA 55-300mm {using the Pentax adapter control} did, and I wasn't positive whether the lens is actually sharper or whether the means of limiting aperture was the real issue. If I get motivated to test again, the obvious solution is to test the Sigma lens using the adapter to control aperture.
That's just the difference between lenses and/or apertures (i.e. if one lens was set on f/5.6 and the other at f/4). The adapter has no aperture of its own (the blades you see in it is the leaf shutter, not the aperture) -- the ring on the adapter just pushes the aperture lever on the lens for you. So as long as you are hitting the same spot for your target aperture, then it doesn't make sense that one would be sharper than the other because there is absolutely no difference between them -- it is the same aperture blades set to the same setting by a different method. It is just a lot easier to use the click stops on the lens if they are available...
12-11-2016, 12:17 PM - 2 Likes   #1172
Mikesul's Avatar
Unapologetic thread revival
This was always one of the most interesting and inspiring Q forum threads. It has been dormant for almost 9 months so I thought I would try to revive it. I confess my Q7 has not been getting much attention lately and I just sold my original Q but I love the little camera so I got it out to play today with the DA*300. The attached photo is not much as art but it does show the detail that Q plus adapter plus DA*300 can achieve even handheld. Please let me see some of your recent extreme telephoto shots with the Q. It won't be hard to top mine of my neighbors pigeon deterrent
PENTAX Q7  Photo
12-12-2016, 12:02 AM - 5 Likes   #1173
Taken with Q7, photodiox, & F* 300.
11/15/2016 Supermoon - Pentax Q7, on Flickr
01-19-2017, 10:30 AM - 1 Like   #1174
Awesome moon shot rgknief60. Shows excellent moon detail.
Thanks for sharing
barondla
---------- Post added 01-19-2017 at 11:38 AM ----------
Amazing detail in a handheld Q/300mm image Mikesul. I've had limited luck using Q/Pentax 55-300 handheld. Never achieved a shot as sharp as yours using the DA*300 hand held. My problem is focusing. I can hold lens steady for a brief instant, but not long enough to manage focusing the big 300. I need more practice! More a monopod/tripod man.
Thanks
barondla
01-19-2017, 11:52 AM - 1 Like   #1175
reh321's Avatar
QuoteOriginally posted by barondla;3886594[COLOR=Silver:
][/COLOR]Amazing detail in a handheld Q/300mm image Mikesul. I've had limited luck using Q/Pentax 55-300 handheld. Never achieved a shot as sharp as yours using the DA*300 hand held. My problem is focusing. I can hold lens steady for a brief instant, but not long enough to manage focusing the big 300. I need more practice! More a monopod/tripod man.
Yes, much beyond 50mm I found that I couldn't hold the camera sufficiently steadily by myself to MF - so I got a MeFoto walking stick / monopod which doesn't meaningfully add to my load but greatly increases my ability to hold on target while focusing.
01-19-2017, 12:22 PM   #1176
Once, I tried handheld with q10 and 500mm mirror lens and 2x TC.....near impossible to get a shot, so I changed to the M 135mm f3.5(and moved closer to the subject).
01-21-2017, 06:07 AM - 6 Likes   #1177
Q-S1 at 560mm at a distance of about 30-40 feet...
01-21-2017, 03:05 PM - 1 Like   #1178
QuoteOriginally posted by barondla Quote
Thanks! I wanted to use my DA* 300 with the Q to compare, but own a generic adapter
with no aperture control. Atmospheric conditions were not the best for viewing.
Here is the full mooon experiment I tried using using the K-1, DA* 300, and 3 stacked
Pentax Teleconverters, the 2x, F1.7, & HD 1.4. Did not think to try the 2x with the F* 300
and the Q. Wish I had.
Same here. The "instant" seems to get briefer the older I get!
---------- Post added 01-21-17 at 04:14 PM ----------
QuoteOriginally posted by wildman Quote
Amazing. Nice sharp image with lots of detail. Could you see yourself in it's eye?
I assume that the image is not cropped.
Do you remember at what aperture (mark) the Pentax adapter was set? That's helpful info.
01-21-2017, 03:45 PM - 5 Likes   #1179
QuoteOriginally posted by rgknief60 Quote
f/7.1 not cropped.
Another one at 560mm not cropped...
01-21-2017, 07:12 PM   #1180
Excellent images, wildman. The feather detail is superb.
Thanks for sharing
barondla
01-21-2017, 09:02 PM   #1181
Thank the glass for that - not me.
01-22-2017, 12:20 AM   #1182
Thanks for sharing
I second that!
Wow! "Your lens takes great pictures!"
Seriously, you have some great technique and skill behind that shot.
I doubt most folks could take your gear and reproduce that. I know I'd like to try!
01-22-2017, 07:53 AM - 2 Likes   #1183
Thanks for those kind words but don't forget all the failed shots you never see.
A low light understory shot...
01-22-2017, 08:32 AM   #1184
Mikesul's Avatar
Can you get this quality handheld? They are really impressive photos.
01-22-2017, 08:49 AM   #1185
No - or at least I never tried it. My setup is strictly tripod mount. Take a look at my gear and you will see why....
adaptor, camera, focus, frame, hummingbird, images, iso, loupe, marco, mirrorless, nikon, pentax, pentax q, pentax q10, pentax q7, q-s1, q10, q7, setup, shot, shots, sigma 500mm, sort, thanks
Post your "Park Bench" "or "Picnic Table" images tessfully Mini-Challenges, Games, and Photo Stories 2199 2 Days Ago 10:28 AM
Don't say Pentax "Q" in French ... "Q" = "cul" = "A--" Jean Poitiers Pentax Q 52 11-10-2013 06:25 AM
"Focus Adjustment Washer" replacement...(with images) Catalana Pentax K-5 & K-5 II 18 11-04-2012 03:40 PM
"Real Life" K5 AF.C images yet? jpzk Pentax K-5 & K-5 II 69 02-02-2011 03:48 AM
How do I turn this so-called "film" into images? Todd Adamson Pentax Medium Format 12 01-07-2011 03:33 PM
All times are GMT -7. The time now is 11:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
